concrete and asphalt
Discussion in 'RC Drifting and Setup' started by sonic, Aug 13, 2004.
  1. sonic
    sonic Guest
    I've learned that PVC works great on asphalt if you want to slide like your on ice. But, if you want a little more speed and control try concrete. I found a concrete loading dock not being used and it is GREAT. The only fallback is the pvc will wear faster, but who cares its 4 bucks for a 10ft pipe.
  2. magnat
    magnat Guest
    a Loading dock ?? are you no afraid that it will fall off and smash from that kind of height ??
  3. SpArKeY_STi
    SpArKeY_STi Guest
    These arnt glass ;) I used to jump my Micro RS4 off 3 ft loading docks trying stuff like that. So long as you have your body on, and you put it togeather correctly, should only break a part here and there, but nothing really important.
