Computer Track Layout Programs
Discussion in 'Track Planning' started by frenchtoast, May 21, 2005.
  1. frenchtoast
    frenchtoast New Member
    Just wondering if anyone uses any track layout programs on their computer? I've just recently downloaded and am trying out Railmodeller for MAC OS X. Its reasonably good for what it does.
    Any other recommendations
  2. nolatron
    nolatron Member
    I've searched around before, and I think railmodeller is the best available for OS X, especially at it's price.
    i've designed all my layouts with it and have been happy with the results.
  3. babydot94513
    babydot94513 Member in training
    I use Right Track from Atlas, but realistically I suspect that any CAD program is about the same. Use what you like and are familiar with.
  4. VunderBob
    VunderBob Member
    I also use Right Track. The good part is that the software is pretty realistic regarding how much space the track and geometry will take on the layout; the bad is that you're locked into using Atlas sectional and flex track, although you can sort of make up your own curved turnouts.
  5. shortliner
    shortliner Member
    I believe that XTrkCad - free from Http:// - can be run with Linux, if that helps. Good set of track libraries, and you can set up your own
    Shortliner(Jack)away up here in the Highlands
  6. babydot94513
    I have also downloaded the XTrkCad software, but have never really figured out how to use it as easily as I figured out RTS. The other thing about XTrkCad is that the library has several obscure manufacturers that I have never even heard of.
    That being said, I recognize that the software has to meet multiple demands in a host of other countries where these track products may be available; however, it is also a problem with RTS in that you cannot "edit" the library to eliminate Atlas track components that you (I) would never use - a re-railer for instance.
    I guess for free you get what you get and use it to its best advantage. If it works for you - then happy modeling!!!
  7. siderod
    siderod Member
    For my trackplan designs that i do for people, a part of SRDesign, i use a good variation of CAD programs, including RTS, XTrkCAD, 3rdPlanIt and a couple other non-rail-specific CAD programs. For most of the plans i'm giving to other people, again through SRDesign, i use RTS, as it uses track people know and have best access to, and it shows more of how it's laid out, especially easy for a beginner.
  8. shortliner
    shortliner Member
    Jeff - here in UK Atlas track is almost unobtainable - we mainly have PECO and HORNBY - with a smattering of VERY EXPENSIVE track by other manufacturers. I'm interested that you found the Atlas Program easy, and XTrkCad less so - I found Atlas very difficult, but maybe that was because I was used to XTrkCad. Like all CAD programs, it has it's quirks, but a friend who used 3rdplanit came over to XTrkCad because he found that much easier to produce results with. All my trackplans on the Small Layout Design Group and it's sister groups - together with the trackplans for Model Trains International magazine are done with XTrkCad.
  9. Dave Farquhar
    Dave Farquhar Member
    I use XTrkCad and I've been pretty happy with it. Since I'm in 3-rail O and use sectional track I had to manually enter all of my track sections in it, but after that, within an hour I was making track plans.
  10. babydot94513
    Hey, Shortliner - we have to swap phone calls, but my wife would kill me if she saw this long distance call.
    I guess each CAD application has its learning curve and I just wish I could figure them all out.
  11. shortliner
    shortliner Member
    Jeff - there is a YOOHOO group at
    It's fairly quiet, but you can get answers to problems on there. FWIW The Help file contains everything that appeared in the printed document that came with the purchased version.
    I'm at chacmool at lineone dot net if you are stuck - can't guarantee to have ALL the answers though <BG>
  12. bubs
    bubs New Member
    Auto2005 works for me, I tried xtrakcad, and I cant figure it out
  13. babydot94513
    Yahoopsie has a group for anything. Next thing you know they will have a group for how to use The Gauge list<g>
    For me, I have XtrkCad installed, but will stick with the Atlas RTS application as that is what I am familiar with.
    Old dogs - no new tricks.
  14. Diezel
    Diezel Member
    I'm on the RTS website but it dosen't have any libraries for G scale? :(. Is there no
    3d design program? you know where you can input 3d structures and create your track etc..?
  15. b28_82
    b28_82 Member
    I have Cadrail 6 and it works great if you take the time to go through the tutorials and try to do exactly what they do to see if you get it right. Also if you take the time to play with all the options that you learn in the tutorials it can become very easy.
    I originally was overwhelmed by all the little functions that it had. I finally took the time to go through the tutorial and it ended up being pretty easy. I even printed my plan out and put it together and the tracks ended up lining up perfectly to the Ntrak standard!
  16. 62cj5
    62cj5 New Member
    dos any one know how to get o27 radius on carves in rts7
  17. seanm
    seanm Member
    XtrkCad is not something you can just pickup and start using. The included toutorials will show you how to get going and even someone like me, could't get Atlas's program to work, was able to figure it out. Use the tutorials!!
  18. 62cj5
    62cj5 New Member
    I can run Rts.7 I am look for the library for O27 gauge carves
    you can,t use it if you don,t have the rite radius on the carves
  19. ajroland
    ajroland Member
    I use 3rd Planit. I am new to the hobby. This program is very good. I will admit though it has taken some effort for me to learn all of its features.
  20. shortliner
    shortliner Member
    RTS7, AFAIK, is for Atlas HO track only, just like it's predecessors, so your chances of using it for )27 are almost non-existant. Try XTrkCad.
    Shortliner (Jack)away up here in the Highlands
