Compression for an RZ-VO1B?
Discussion in 'RC General & Getting Started' started by BLIZZARD, Sep 1, 2003.
Thread Status:
  1. BLIZZARD
    BLIZZARD New Member
    I just finished breaking in an RZ-VO1B and was curious what P.S.I. I should expect at this time of the motors life. I purchased a Compression Tester and I want to keep track of the P.S.I. along the way. I just don't know what an average base line is to start out with. I know it is more than 60psi., because when I used my old tester, it pegged the needle!!!, so I purchased a 200psi tester! Thanks to all, Mark.
  2. toby
    toby New Member
    I don't know if there is a set PSI. You might try e-mailing the manufacturer and see if they have a value for you. If you just broke it in and everything is running smooth then I would get a reading and use that as a baseline for future checks. This way, you can tell when the engine is starting to get worn.
  3. BLIZZARD
    BLIZZARD New Member
    Thanks Toby, I was still curious if any one has the same motor and has done compression checks, what were the results?
  4. toby
    toby New Member
Thread Status:
