Chaging PDF scale of downloaded models please
Discussion in 'General Card Modeling' started by ckinnell, Jul 12, 2010.
  1. ckinnell
    ckinnell New Member
    Can any one please explain a quick and simple way of accurately changing scale of models D/L in PDF format, as, i like to model in 1 to 1oo scale, locos and all vehicles etc etc, say 1/87 to 1/100 or 1/120 to 1/100.
    If their is a free to download and use software D/L to be found that will do this automatically, please can some one tell me where it is found, or, if not, how i can as stated above, do alterations but simply and straight forward, to achieve my goals please......
    Thanks for all help in this matter and best regards to one and all.
  2. Tirick
    Tirick Member
    I use GIMP to rescale (it opens regular .pdf's just fine). Explaining how to do so however is beyond the scope of a single reply.
    It is a free program however. If there is enough interest I can write up a quick tutorial.
  3. Lord Manimal
    Lord Manimal Member
    I normally just take a measurement of the real model, say if I'm making a paper Leman Russ, open up the PDF in photoshop (you can open up pdf's directly btw) and then select the whole image and move up or down till the size of the one peice I measured matches; the rest matches automatically of course. Don't know if that helps or not...
  4. ckinnell
    ckinnell New Member
    Thanks to both, will give each suggestion a good look at, regards and grateful thanks to both........
  5. karsaeras
    karsaeras New Member
    Very useful topic!!!!
    thanks to both
  6. MAGI
    MAGI Member
    Great information.
    I was just looking at a train I downloaded but it was too big from my city I am working on.
    Good old GIMP.
    love it and forgot it opened PDF's.
    Thanks for the information, think I can get it from here.
    I decided to play around with this. I opened a PDF then captured part of it with grab, this is an easy way to crop parts and converts them to TIFF. I then opened the TIFF and saved it as a JPEG.
  8. rthompson10
    rthompson10 Guest
    Try Foxit PDF reader its free and you can print in any scale you want. On the print page there is a place you can change the scale to what you want then hit enter and lock it in then print...a very good print prog....Rich
  9. Eyeonmal
    Eyeonmal New Member
    Would be keen to see a tutorial on this matter at some point, would be very valuable I reckon!
  10. Slickaa
    Slickaa New Member
    Can anyone advice when we take a snapshot in Adobe reader and paste onto paint does the scale or aspect changes?
  11. Well, Slickaa, if you do a screen capture while your Reader image is up, the image you captured will be the exact size of your screen resolution. However, a captured image is a bitmap, which cannot be enlarged without loss of detail. One advantage of having many models in the PDF (Adobe Reader) format is that models can be vector images, which means it can be enlarged without detail loss.
    There would be no advantage to printing the way you describe, though. If you want to enlarge a vectored PDF, you have a couple of options. The easiest is to use Reader's zoom feature to zoom in on a part, then, in Readers print feature, designate to print the screen. You might have to do 3-4 prints for each page this way.
    I have also enlarged PDF files after importing them into a vector editor, such as CorelDraw, and enlarging the pages to a specific percentage. To do this you need to separately select the individual shapes and reposition them to fit on pages. This takes a good bit of software skill and also doesn't work with all PDFs.
