card shipmodeling
Discussion in 'Ship & Watercraft Models' started by deshpande, Apr 7, 2007.
  1. deshpande
    deshpande New Member
    what type of card ( thickness ) should be used for card modeling.
  2. paper warrior
    paper warrior Member
    Thats really a question pf preference/use/scale/ect. ect. I would recommend 65 lbs. card. Gil should be able to give you a bit more insight.
  3. paulhbell
    paulhbell Guest
    Deshpande, I use 120gsm and 180gsm paper/card. The 120gsm is quite bendable (good for curves), where the 180gsm is quite strong ( good for walls, ships decks and superstructure).
    Normal printer paper, 80gsm, isn't bad for general use. I also have 240 gsm which is strong stuff, but won't fit in my printer.
  4. barry
    barry Active Member
    Everything from cigarette filter papers to 200 gsm and 1mm depends what you are doing......1mm for frames cigarette papers for 40mm barrels
  5. paulhbell
    paulhbell Guest
    I never thought of using cig paper before, that's a good tip. But get them while you can, before smoking is banned.
