Carb help
Discussion in 'RC General & Getting Started' started by danny_holtermann, Jan 15, 2004.
Thread Status:
  1. I have a velocity 15 engine, the gas isn't reaching the piston. There is a low speed needle that is connecting to a little rod, could that be the problem w/ it?
  2. bandit1
    bandit1 Member
    im not sure but did u check if maybe the nozzle that u attatch ur line to is blocked by something? if its not that im not sure wat i could be.
  3. No But I will check and tell you later
  4. hey bandit I went and got a metal one , but im scared it might leak
  5. tec
    tec New Member
    Not quite sure on the set up,connected to a rod sound like idle, but that is obvious. Check the tank around the cap (all over) for leaks and replace hose. If it uses exhaust to pressurize the tank that tube also should be checked(a leak in the exhaust gasket or bad baffle(muffler) will loose backpressure and not force air into the gas tank then into the carb. Assuming it about the same set up
  6. I got it fixed thanks
Thread Status:
