Can You Artists Out There Help Me?
Discussion in 'Scratchin' & Bashin'' started by Lighthorseman, Jun 13, 2003.
  1. Lighthorseman
    Lighthorseman Active Member
    I'm in the process of scratchbuilding a bar for my layout, and I'm not good enough to create a good-looking sign. I did come up with an idea, though.
    Can anyone improve on this?:)
  2. billk
    billk Active Member
    One thing I can think of is - depending on the size of actual size - the thin lines of the cloverleaf might make it hard to see. Also the letters appear to be a light green, maybe using white would provide a better contrast, and the braid also is hard to see since it appears to be a dark green. The braid might be a little too "fancy" in real life, as well.
    You should be able to find a useful cloverleaf image on the net somewhere. Try a search for "4H" and remove the "H"'s??
    But overall, I like it.
  3. MasonJar
    Clip Art
    Hi Steve,
    You can probably find what you are looking for from Micro$oft's clip art downloads. Try searching for "borders" for the braid.
    The only drawback is that you will need to use M$ products to manipulate the download.
    Let me know how it goes...!
  4. Matthyro
    Matthyro Will always be re-membered
    Steve, That's a very nice sign you designed. It should look good on the bar. I know there are probably thousands of different signs you could use but yours should do fine.
  5. N Gauger
    N Gauger 1:20.3 Train Addict
    Steve, I might be able to help you... Give me the Width and height you need & I'll see what I can do.... :) :)
  6. Clerk
    Clerk Active Member
    I agree with Robin. I like the sign just as is. I asked my wife about it and she said it is great. She is Scottish.
    Also, that is not a clover leaf it is a Shamrock
  7. jmarksbery
    jmarksbery Active Member
    How's this Steve :rolleyes:
  8. sapacif
    sapacif Member
    I like jmarksbery's sign the best. My idea would be to make the name and the shamrock dominate. Then, add those other details. I made a sign that had a lot of neat slogans, times, etc on it. I felt that the impact of the sign was lost in the detail. You had to stop and read it. If your sign said "Ghallager's" or "Ghallagher's Pub" in big letters, all the other information could be determined while you were in the bar having a cool one!
  9. Lighthorseman
    DUH!! I CANNOT believe that I called a shamrock a cloverleaf! (Whit wis I daein'???):D
    JMarksberry...Thanks! I'll give that one a spin. It sure looks better than mine.:)
  10. N Gauger
    Here's my idea J :) :)
      File size:
      10.3 KB
  11. shaygetz
    shaygetz Active Member
    Oy, I was thinkin' to meself, I says, "Self, you spent three St. Patty's weekends workin' in a hotel, cleanin' up after the Irish Fire Brigade come down from Philly to spend a weekend at the beach, drinkin' green Guiness and stuffin' corned beef and cabbage down the commode. Now you sees this here sign and you're thinkin', 'Send the fireman to the new pub up the street and let them clean up after them.' ". Nice work guys and a great handle on the Gaelic there, Lighthorseman. When you open up, let me know and I'll send the Irish Fire Brigade your way. Don't worry, I'll send a plunger too.:D
  12. Lighthorseman
    Thank You!!
    N Gauger...Thanks to you, too!
    Now I just have to finish up the building for my snappy new signs!:)
