can the lionel engines run on krail track?
Discussion in 'G / O / S Scale Model Trains' started by ozzy, Jun 25, 2006.
  1. ozzy
    ozzy Active Member
    i was surfinh ebay, and found the same santa fe #212 engine says on the side, "BLT 8-57 by lionel, but they have it setting in krail, i think its k-rail, K somthing.
  2. Greg Elems
    Greg Elems Member
    As long as it is 3 rail and 1.25” gauge, Lionel can run on it. It was probably K-Line track you saw it on.
  3. ozzy
    ozzy Active Member
    so i could run the newer lionel trains on my old lionel track then?
  4. Marxed
    Marxed Member
    regardless of age, as long as its the traditional 3 rail track, it should go, i have some 70 year old 0-gauge track on my layout
  5. 60103
    The only problems of compatibility in 3 rail trains are that some of them need wider curves.
    Some of the older trains required heavier track. Sometimes a loco will not like a different manufacturer's switches. Not all makes/series of tracks will join together -- the ones with roadbed moulded on are the worst; Lionel has 3 incompatible series.
    Some trains have different couplings.
