Can a RC Boat be used in a Swimming pool chlorinated with a salt system?
Discussion in 'RC Aircraft & Watercraft' started by stanholio13, Apr 17, 2007.
  1. stanholio13
    stanholio13 New Member
    Many manufactures of RC boats say "Do not use in salt water".Does this apply to a swimming pool chlorinated with a salt system? The salt is broken down into chlorine.
  2. liquidus
    liquidus New Member
    yeah why not, water is water, unless ur boat uses some kind of organic salmon based propulsion system that works by filtering pure water.... tut tut tut think about it
  3. urbancoyote
    urbancoyote New Member
    If the WATER tastes salty, don't put the RC boat in it. But if the water tastes like fresh water, it is OK for the RC boat.
  4. scubabob
    scubabob New Member
    The salinity of a salt water generated pool is in the 2500- 3500 ppm range. If you're Julia Child and an excellent cook, you might taste it. The salinity isn't corrosive to pool heaters or ladders and such, so ought to be just fine for that RC boat, even if it is water cooled like mine is.
  5. exbuilder
    exbuilder New Member
    You shouldn't have any problem. Just make sure you rinse the boat with fresh water after using in salt water. Salt water will cause metal parts to corrode faster than fresh water. Good luck with your RC boat.
  6. sfdegdgg
    sfdegdgg Guest
    金诚信四方卡识别技术有限公司
    北京金诚信四方卡识别技术有限公司是一家专门致力于金融技术应用产品的研制、取号机开发、生产、销售的高科技企业。叫号机公司坚持产业化的发展道路,取号机现已形成以磁条读写器取号机、叫号机划卡键盘、取号机密码键盘、金卡键盘、叫号机排队管理系统为主的全系列的金融外设产品
