C-liners on the Blackwater Sub.
Discussion in 'HO Scale Model Trains' started by Glen Haasdyk, Dec 11, 2005.
  1. Glen Haasdyk
    Glen Haasdyk Active Member
    Here's Three C-liners coming out of the tunnel in Blackwater, pulling the daily passenger.
    Only the lead engine is actually mine, the others belong to a friend who had me add all the grabs to them. That takes some time and a steady hand. :D
  2. Ralph
    The grab irons really add to the look of that fine lashup!
  3. doctorwayne
    doctorwayne Active Member
    Another classic paint scheme. Are these the Proto1000 version? Before these were released, I did one for a friend using the old AHM body on a Stewart Baldwin drive, painted in CNR colours like your Trainmaster. When the Protos came out, he picked up an A-B set and all three actually run very well together. I'm also pleased to say that the original that I built stands up quite well, appearance-wise.
  4. MilesWestern
    MilesWestern Active Member
    Didn't all the C-liners have a B-C wheel arrangement? (C for Consolidation, 10 wheels)
    Glen, what wheel arrangement do yours have?
  5. Drew1125
    Drew1125 Active Member
    Nice looking lash-up, Glen!
    :thumb: :cool: :cool: :thumb:
  6. doctorwayne
    The C-Liners came in either a B-B or a B-C wheel arrangement. Life-Like Canada is bringing out the five axle version sometime next year. From what I've heard, they'll be doing A units only, along with the running gear to make your own B unit. Evidently the four and five axle B units were the same length, so you can just supply your own body shell from a B unit that you already own. Sounds kind of silly to me: why not just sell it as a complete unit? Who would want to be left with a perfectly good four axle mechanism with no body?
  7. Glen Haasdyk
    These are the Proto units. I do have a line on a couple of the older AHM units, one A and 1 B Complete with Athearn drivetrain components to make B-C axle units out of them. The AHM bodies aren't too bad, once you remove the oversized pilot and add some proper grabs to it. Of course they are allot more work than the protos since all you have to do is add the grabs which take about an hour per unit.
  8. ross31r
    ross31r Member
    Actually, AFAIK the three-axle trailing bogie was only on the passenger versions to reduce the axle loading as these units carried a steam generator in the back of the carbody.
    Hence the C-Liner 5-axle units are actually passenger units whereas the 4-axle ones are freight units.
  9. MilesWestern
    Wha t does "AFAIK" mean?
  10. CN1
    CN1 Active Member
    Very Nice Glen. :thumb: proto makes fine Canadian models :wave:
  11. sumpter250
    My SWAG (scientific wild ***guess) would be "As Far As I Know" :D :D
    I hadn't heard that explaination before. Makes sense, but doesn't explain the limited number of roads that used the 5 axel units. LIRR, and New Haven come to mind, and I can't think of any others.
  12. Chessie6459
    Chessie6459 Gauge Oldtimer
    :thumb: :thumb: :thumb: Looks Good.
  13. MilesWestern
    Thanks sumpter250, All this jargon had me confused! LOL....! :D
  14. Glen Haasdyk
    It has always been my understanding that CNR had the only 5-axle C-liner units, being used for passenger use. Other railroads (as well as the CN) used other passenger units like FP's ,PA's ect.
    CN also used FPA-2 and FPA-4 units, basically FA-2's with a steam generator in them.
    On another note the CPR used 4-axle c-liners in southern BC (crowsnest and kettle valley div.) on passenger trains.
  15. ross31r
    ross31r Member
    yes it doesn mean As Far As I Know!
    and yes, it would explain why a limited number of roads used them - most road would probably have rather had a "proper" passenger units such as the PA or E series rather than what was effecitvely a full sized "kitbash" of a freight unit.
