burned esc
Discussion in 'RC Offroad Forum' started by bigsexy2177, Mar 21, 2005.
Thread Status:
  1. bigsexy2177
    bigsexy2177 Member
    i have a novak dualy in my rustler and i dont know what is wrong with it. there is power going to reciever and sterring. the on/of switch works. the thing is that it does not move. the wheels do not move. some of the time the wheels just go by there own. one time there was smoke that cam out by the motor and battery wires from the esc. is it possible that the esc got wet. please let me know. Matt.
  2. dj6666969
    dj6666969 Active Member
    it sounds as if it is burnt
  3. magna_matt
    magna_matt New Member
    You probably burned through one of the power FET's. You could take it apart, and look for any burned/blown components. Usually it will be in the transistors that are under the heat-sink.
    But smoke coming out is not a good sign.
  4. gaz_r36
    gaz_r36 Member
  5. ty923
    ty923 Member
  6. gaz_r36
    gaz_r36 Member
  7. rustler
    rustler Member
    it could be the differential
  8. gaz_r36
    gaz_r36 Member
    or it cud b dead
  9. redheat
    redheat Member
    Did you set your Tx to nuetral setting before setting the ESC? RED
  10. Justin_E
    Justin_E Member
    it mite b the motor...
Thread Status:
