bumper stops!!
Discussion in 'Scratchin' & Bashin'' started by Xaniel, Jul 19, 2002.
  1. Xaniel
    Xaniel Member
    hi there,
    i really need to know how can i scratch build some bumper stops! really need to know... can you fine people show me some pics from it?
  2. BillD53A
    BillD53A Member
    I can think of 3 ways to stop cars at the end of a track, that you can make easily. The first is a simple mound of dirt, or ballast. Just put a pile at the end of track and glue it using whatever method you use for your track ballast. The second uses 2 cross ties (sleepers). Put the end of one loose tie under one rail of your track, with the end between two ties. The other end lies on top of the opposite rail. Cross the two ties so they form an X. The third way is to simply glue a single tie acrosss the rails. On the real track the tie would be bolted to the rails. HTH Bill
