Hi:
I’m still a novice at trains but I’ve been drawing buildings for 25 years so thought I’d throw a couple things into this discussion. Most of what I list applies to buildings built from 1940-45 onward. That’s when “modular” construction materials and “platform framing” started coming into use. Most also refer to commercial or industrial buildings. Residential is more of an “anything goes” kinda market.
1. Modular standard bricks run 3 courses to 8-inches vertically and oversize modular brick runs 5 courses to 16-inches. Both sizes course out horizontally to 8-inches long. This is so the brick facing will course out with the concrete masonry unit (Concrete Block) backup. You’ll also find 4-inch course brick “jumbos” on industrial buildings, again, so they will course out vertically with the CMU backup. Most brick/CMU coursing will start out even with the finished floor and then go up and down from there.
2. There are many exceptions to #1. Brick is made in dozens of shapes and sizes, especially older brick. But most all of it will stick to the 8 inch or 16 inch vertical modules even when they use solid brick without CMU backup.
3. When using steel framed doors, a 6’-8” high door will have a 2-inch head frame. A 7’-0” door will have a 4-inch head frame. This is so the door frame will course out with the brick/CMU. This can help you decide what the door and what the brick size is, if they match out at the head and the brick/CMU isn’t cut to fit the door head height. Most exterior doors are 3”-0” wide. 50-60’s era residential doors tend to be 36 at the front door and 34 inch elsewhere. Older structures could be most anything because it was up to the carpenter in many cases to make it from scratch. Our front doors at work, building built in 1920, are 3’-8” wide and 9’-10” high.
4. Door knobs are usually 34-42 inches above the floor. Sometimes 48. This is especially useful to remember on monumental buildings like churches, town halls, etc, where the doors may be oversize and the walls made of cut stone. 5. Wood has come in “standard” sizes since the 40s and fifties. BUT, it has been steadily whittled down from a real 2x 4 to 1.5x 3.5 inches. The one by lumber has paralleled this sizing. This can help you figure out fascia sizes. 8 inch facia, 10 inch facia, 12 inch, etc.
6. Overhead doors at docks started out at 7 or 8 feet wide and 8 or 9 feet high. Now we make most of them 9x 10 high at docks. Most over head doors are sectional and the panels are 2’-0” high. Coiling door ribs are about 2 – 3 inches high.
7. Windows vary but usually course out with the brick. Most window sill heights also course out with brick, 2’-4”, 3’-4”, etc. above the floor.
8. Work counters are usually 3’-0” high or 3’-6” high.
9. You can also use people in the building photos to set the scale. We know how big they typically are.
Mainly, just use Davidstrains advice and make it look like you envision it. It is, after all, your empire.
Regards,
Ted
