Building the Enterprise E
Discussion in 'Science Fiction & Fantasy' started by trekman1017, Dec 15, 2008.
  1. Millenniumfalsehood
    Can you be more specific? AFAIK, the bottom of the saucer is simple laminating. All you need to do is glue the individual layers to a piece of thicker cardboard, cut it out, and glue gray strips to the exposed cardboard edges. Then glue the layers one at a time to each other and then to the bottom of the saucer section.
  2. trekman1017
    trekman1017 Member
    what sheet do i get the windows from?
  3. Adecc
    Adecc New Member
    Just been working on this model myself.
    If you mean the inset windows on the saucer underside laminations then they are printed on Sheet H on two grey strips in the V section of the larger saucer part.
    The larger front window part is made up of two pieces that are on the same sheet printed in the V of the smaller saucer part.
    Hope that helps.
