Building GPM aircraft models
Discussion in 'Aircraft & Aviation' started by billmcc, Jul 2, 2004.
  1. billmcc
    billmcc Member
    Hi All,
    I want to build the F-117 Stealth and a few other aircraft models by GPM, but I have no knowledge of the notations GPM uses on its models.
    For example, a "W" inside a white area seems to mean you cut out the white area. Is this correct? An "L" and a "P" in a part's designation seems to mean that it is a left or a right part. Is this correct?
    Please explain all of the notations, symbols and conventions you have encountered on GPM models. Please!
    Regards, Bill M.
  2. Swinger
    Swinger Member
    You are right.
    L, lewy/lewe/lewa = left
    P, prawy/prawe/prawa = right
    W, wyciac = cut out
    Wyciac po sklejeniu = cut out after assembling
    tu czesc x = here part x
    drut = wire
    szpilka = pin
    If you need anything specific, just ask about it.
  3. billmcc
    billmcc Member
    Thank you very much for your assistance. I will probably ask for more help when I start building the GPM F-117.
    Regards, Bill M.
