Build Firefox (MiG-31)
Discussion in 'Aircraft & Aviation' started by firefoxussr, Aug 15, 2013.
  1. zathros
    zathros SENIOR Administrator
    You are doing a great job, just find something to take of the white seams, or paint the whole thing when your down. I would use a flat, or semigloss black to keep the stealth look consistent. Very nice work you are showing here.
    The model is in the "Downloads" section, this model also is the uploaded version by "Janx":
  2. Rhaven Blaack
    Rhaven Blaack ADMINISTRATOR Administrator
    You are off to a GREAT start.
    If you colour the edges before you glue the parts together you stand a GREAT deal less of a chance of getting paint on the printed areas.
    I normally use water colour paints to colour the edges.
    I see that you have "SHARPIE" markers. those are good at colouring edges, but be careful as the ink can "bleed" into the paper and ruin your project.
    Keep it going!!!
  3. firefoxussr
    firefoxussr thief
    Thanks I was wondering how that would work out. I will be very sparing with the sharpie. I have/had one with a fine point and a broad point, I might use the fine instead.
    This being my first build, I'm just familiarizing myself. My plan is to:
    -Finish the Firefox as per the instructions.
    -Build a Ferrari F50 GT (very special version of the normal car!)
    -Build an RCPowers Firefox (after I build a trainer foamie first)
    -Re-paint a BMW M1 paper model as the BASF version
    -Build a YF-23 or X-29 or Su-47
    -After that I would like to do an original design (probably G1 Wheeljack or Sky/Jetfire)
    -Do a scale up & re-texture of the Firefox (balsa/carbon supports, got an idea about the getting the skin to look right too- very inspired by the X-Wing build up thread).
    Speaking of which, I don't have much of a 3D background, any good tutorials to get me into doing Pepakura models?
  4. Rogerio Silva
    Rogerio Silva Active Member
    GREAT job, man! That's definitely a must have.
  5. Janx
    Janx Member
    Excellent job so far :).
    There maybe a few errors in the instructions. I inrended to fix em but lost the original files along with cockpit and missile bays in a hdd crash a few years ago.
    let me know if you need any help.
    ps Ive started work on revised model approx 1/33rd scale.
  6. micahrogers
    micahrogers Active Member
    This is looking great so far, keep at it, and take your time, I tend to rush things, then get "Burned Out" and have to get back in the grove.
  7. zathros
    Janx, if you only knew how many people come to this forum looking for this model. They get so angry they have to wait to get it but all do. A few disappear afterwards, but most hang around. You really have a winner here.:thumb:
  8. firefoxussr
    firefoxussr thief
    Thanks, I think I've got it. So happy I don't have to scratchbuild one... thought I was alone for years on this project.
    I'm excited to hear there may be an upcoming 1/33, if you want someone who is a photoshop/illustrator expert (and real pro graphic artist) hit me up.
    I should be able to continue my build today after a long and fun weekend (I like to race cars... 1/1 as well as RC).
  9. firefoxussr
    firefoxussr thief
    Shape that fuselage and glue it to the first fuselage section.
    So I scored part of the fuselage underside, but as it turns out there is another crease by the midwing.
    That crease.
    Building the ventral intake vent required a bit more interpretation that I was ready for. But I got the gist.
    Or did I? Turns out you shouldn't glue it to the dorsal fuselage first.
    Once I figured out that it actually affixes to the fuselage section one extender (piece 11 or 12), then it made sense to attach the vent there, then put in place the wing roots and the lower fuselage skin.
    So far so good. Next session i'll create the missing link needed at the tail end of the fuselage.
    This session was somewhere between 2 or 3 Mythbusters episodes (had it on Amazon vid while building). Learned a lot about folding and scoring and shaping. Perhaps an updated version of this should break up step 4 to explain the vent. Another suggestion would be more explicit instruction on where to put bends in the paper.
  10. zathros
    Wow, She's really coming along nicely!! :)
  11. Rhaven Blaack
    You are really going to town on this build.
  12. Shipmaker
    Shipmaker New Member
    Awesome build. I'll keep watching and learning. Thanks
  13. Rogerio Silva
    Great build so far, man. Keep it up!
  14. firefoxussr
    firefoxussr thief
    Lots of glue on those wing roots/supports. I find that the paper folding ability i have things don't quite match up, so use glue like resin and make sure the structural things are there.
    This seems like where the wingspars are supposed to go. It's about a 1/8" recessed, right up against the inner wing frame. To be honest the difficult part is getting the wing to do the curve on top and getting the aft section to stick to the tab. I ended up using the scissor blades inside and my thumb outside to press them together (this applies when both the top and bottom wing skin are in place).
    And the model is complete. The worlds first papercraft Firefox rocket.
    But for real... I saw this years ago and said... don't tease me bro
  15. Cforrest900
    Cforrest900 Member
    . You deserve much applause. VERY CLEAN build and it's the FIRST OF ITS KIND! You have set the bat high, my friend.
  16. arkon
    arkon Member
    if it was not for the amount of black ink I would have printed this awhile back... glad you did.. enjoying all of your build pics.
  17. zathros
    A white line option that could be spray painted would be nice.
    If you want the best prices on ink go to:
  18. firefoxussr
    firefoxussr thief
    Elaborate, please.
  19. Revell-Fan
    Revell-Fan Co-Administrator Administrator
    I guess Zathros means to provide a white model with lines only. I did it with my Colonial Warrior Blaster and the poseable Crichton figure. Such a version can be printed on regular card and then painted using an airbrush or spray can when finished or to be printed on coloured paper. So the builder is able to save ink. Pepakura viewer has an option to "switch off" the texture of the model so that you can print an untextured / white kit directly from the *.pdo.
  20. zathros
    What he said. :)
