BSG Mule Tractor
Discussion in 'Science Fiction & Fantasy' started by Rhaven Blaack, Mar 5, 2014.
  1. Rhaven Blaack
    Rhaven Blaack ADMINISTRATOR Administrator
    I decided to take a little break from my (tedious) UPLOADING task to make a quick and easy model as well as to honor one of our very own members who happens to a MASTER builder and a really good designer (not to mention that he is also a moderator) Silveroxide, with the build of the BSG Mule Tractor that he designed.
    You can find this model in the RESOURCE Section here:
    This model has only one sheet of parts. It is quite simple but at the same time a good model for those who want to learn how to detail out a model and not worry about frakking things up. Not only that, but it is a GREAT addition to any BSG diorama (as you will see in a later post).
  2. Rhaven Blaack
    Continuing the build.
  3. Rhaven Blaack
    Here are the final photos of this really fun and quick build.
    (As you see, I even added a deck hand to drive it around.)
    As mentioned in my first post, I added it (but not permanently) to my Viper diorama (I may leave it there, then again I am not).
    Revell-Fan likes this.
  4. DanBKing
    DanBKing Active Member
    Nice work, RB.
    Your diorama is stating to come together nicely.!
  5. Revell-Fan
    Revell-Fan Co-Administrator Administrator
    GREAT JOB, PAL!:cool::cool::cool:
  6. silveroxide
    silveroxide Well-Known Member
    Thanks for sharing and you are welcome for the mule. In actuality, I found a photo of the Galactica mule. It is a bit different from the one I designed. This little fellow came about, because back in my BSG frantic build days, I had these multiple vipers and raptor and I had no way of moving them around. This is the reason for the build.
