BlueLine Locomotives
Mannix
49
I noticed that Factory Direct Trains has Broadway Limited Imports HO BlueLine Locomotives with sound for $119.99. An NMRA Standard DCC Socket is included so you can quickly and easily install your favorite decoder. Each locomotive has a factory installed sound system. Has anyone used these locomotives? Are they reliable? How would you rate the quality?
woodone
367
Phoenix, AZ.
Have no experience with these. I did note, that this is a $170.00 unit.
Can use on just DC, but you will need a analog control module to operate the whistle,bell & other sounds. Then you will need a decoder if you are using DCC.
Mannix
49
Do you have any idea as to what an analog control module costs? How does that module work? I am using DCC, but I thought that the price of the locomotive was reasonable.
UP SD40-2
2,709
I have only bought FULL BLOWN BLI's, decoded and with QSI sound, and all the ones i have are SLAP FANTASTIC:thumb: . they have a UP SD9 that just came out i have had my eye on:winki::mrgreen: , its a "Blue line", so I TOO am interested in the facts about these:winki: .
:deano: -Deano
UP SD40-2
2,709
THANKS JOSH!:thumb: thats a GREAT review for DC...cant wait to hear what they are like with a DCC decoder in them:winki: .
:deano: -Deano
woodone
367
Phoenix, AZ.
If you are using DCC I don't think that you need to worry about an analog module. The module is for DC use only, as I interpret the information I read.
Do a search on Blueline, and see what you can find. That is where I saw the info on the analog module.
The price you stated is a good one. MFSLP is $170.00 or so.
Mannix
49
jbaakko
1,082
San Diego, CA
rr.blockchoice.com
Mannix, I'm using sectional track, from Life Like, which does not sit well, normal track with rail joiners might work slightly better.
As for the sound, its BEAUTIFUL! The sound runs off a pre-installed sound only DCC decoder that can run on AC (dcc) or DC. When you switch it to DCC you program the two togeather to make them work togeather, supposedly. I need to pick up a DCC system, so I can test it out (I've got the decoder already).
Tomytuna
28
ok..yesterday sat. 10/13/07 i purchased 2 sd40-2 in santa fe bluebonnett colors...here's my story
1. put 1st on test track @ local hobby store and all seemed well = DC mode
2. decided to purchase 2 units...did not test 2nd engine..thinking 1 wrked well,,second should too!
3. purchsed 2 NCE N14IP decoders to convert engines to DCC ( i'm all dcc)
4. came home and enstalled 1st decoder ( which both Blueline and MR recomend) and it fit nicely...ony it ran backwoards...ok..take out decoder and reverse in..engine runs fine....reenstall engine body cover and NO MOVE!..take off body and find preasure of body is breaking pin contact and not getting reply...will try to play with it some more today and see if i can get contact to remaine tight because so far i like the product....
5. back to 2nd engine...installed new decoder and NO SOUND....I did not tray this unit at LHS...will change decoders and see if that is/was problem...but i guess the moral of story is TEST ALL ENGINES BEFORE LEAVING HOBBY STORE..
6. Any one who has experience with these units, I would like to hear from them with any and all help...(cause i don't want to return them)
7. Thanks...Tom
Mannix
49
Tomytuna, thanks for your reply. I haven't purchased one of the locomotives yet. I have to order it on line as the hobby shop doesn't stock them. Now with all of the problems that you have encountered with the units I will have to do some more evaluating about making the purchase. Keep me posted as you continue to get the bugs out of those two locomotives that you purchased. I too am running DCC. What is the radius of your curves? When you get the locos running let me know if you have any trouble with them derailing on the curves. Do those locos have 8 or 12 wheels? Thanks.
jbaakko
1,082
San Diego, CA
rr.blockchoice.com
Tom, I'm not sure, but if you need help, try the forum on BLI's site. They should be able to help you. For the sound to work in DCC mode, BOTH decoders need to be on the same address, otherwise the sound board's decoder does not know it supposed to be working.
As for the engine you got from the LHS, my LHS (The on I like the most at least) does not allow engines to leave w/o testing first.
Tomytuna
28
hi josh and mannix...i hope i did not discourage from buying one of these as i have many BLI and was excited to go the "Blueline route"...hopefully my issue's are not germaine to all blueline's
Mannix...my minum radiuse is 22'',, and sd40-2 is a 6 axle engine....shour handle tight turns though as most model co know people do not have large space to have large turns
Josh--thaks for the web site..
Best to both of you---Tom
jbaakko
1,082
San Diego, CA
rr.blockchoice.com
I'll continue to buy BLI. They do have the only AC6000CW, and I want more then one. I want an SD9, and at least one SD40-2 from them also. Although, as its looking, I won't need the SD9, as it seems BNSF just sold all the SD9's and B23-7's off.
Tomytuna
28
Good morning all...here is a little update on my blueline issue..between my LHS and BLI ( blueline ) wwebsite i have finally got 1 of 2 engines up and going great. Sound and all performance is working fine and i will purchase more if needed...2nd engine is not going 100% yet but know it is a programing issue and not mfg...Tom ps,thanks to all
redvdub1
2
I have a blue line C&O 2-10-4 with sound only..I like the sound..did do some tuning on it. had to lube the phos bronze spring contacts on the tender wheels to get consistent electrical pick up and I added weight to
the tender. I also removed the tender wheels and bent the phos bronze springs to get better contact pressure on the axles. I would buy another one w/o question..will add DCC soon
