Well, the paint design isn't exactly like this but it's the same colors and the closest I coud find to it.Smoke said:I think that is called the "bookends" scheme, because of the yellow on both ends.
-Smoke
I've never seen an engine done in that paint sceme. Got a link to one?ozzy said:what kind of engines?
what about a blue and silver alco santa fe? i always liked them,
Ok... cool. I put this one on my watch list though.ozzy said:http://cgi.ebay.com/VINTAGE-LIONEL-...oryZ4146QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
like this one but blue where the red is on this one
Will it handle O27 curves? It looks like it would but looks can be decieving.ozzy said:the 218 has lots of power, i have one but my shell is not as good as this one. made from 1959 to 1963
Cannonball said:Will it handle O27 curves? It looks like it would but looks can be decieving.
Actually, my question was whether or not anyone on the board is currently modeling it.Russ Bellinis said:I'm not sure if your question is regarding models released in Santa Fe paint schemes or when did Santa Fe use the various paint schemes on the prototype. The scheme with the yellow ends is also known as the "cigar band scheme" because of the single yellow stripe connecting the 2 ends runing along the top paret of the body. That paint scheme replaced the zebra stripes on switch engines in the 1960's. I think it was in the late 1960's when Santa Fe was experimenting with different color schemes for the new freight scheme that eventually became the blue & yellow warbonnett scheme.
Man, you make it really hard to stay off eBay, you know that.ozzy said:
Russ Bellinis said:I model Santa Fe in the 1950's, so my switchers are zebra stripe, freight F units are blue & yellow cigar band, and passenger F, E, & PA units are red & silver. Anyone modeling Santa Fe in the 1960's would be using that paint scheme.
Thanks for the info, guys. I think I've settled on this as my primary model since it's so hard to find BNSF stuff in O27 that doesn't cost an arm and a leg.Dick Elmore said:Actually, Santa Fe started painting thier engines in the blue and yellow paint,( i.e. bookends), around 1958 and 1959. The cigar band scheme refers to the front logos on the E and F units. All of the passenger E and F units had the cigar band and later the freight F units after the cat whisker paint scheme.
