Blue Foam as Roadbed?
Gary S.
1,576
Texas
My layout shelves are covered with 2" blue foam. As for roadbed, I had planned on glueing cork roadbed on that, but I got to thinking about another possibility. What if I glue the track directly to the blue foam and then carve the foam surface down, leaving the roadbed an integral piece of the foam? Regardless of which method I use, the foam is going to be carved up some anyway, just to eliminate the "flat as a board" layout syndrome.
One concern would be noise factor. I have experimented with both methods, and didn't hear much of a difference in the sound levels.
The cork roadbed method may be a bit easier and would require less carving of the foam. Any thoughts?
viperman
959
Carol Stream, IL
I'm gluing cork on my foam. Haven't run any trains yet, so no idea on the sound difference, I just like the look of the cork, and it's easier than carving EVERYTHING else lower
kitsune
114
There will be a noise differance, unless you're also using, say, ply underneath the foam. That may deaden it a bit. One big thing is cork is far easier to hold track down on. It's also prototypical for bringing it up higher. You may also try Bill Darnaby's trick off the Maumee, and use unsplit N-scale cork for a lower profile.
Personally, carving foam is one of the less fun aspects of the hobby, and I would really hate to *have* to carve it basically everywhere.
slufoot733
4
Gary,
I used the cork-on-foam system on my last layout (which never really got finished) and it worked great. But, that was only on my main lines. For my sidings and the branch line I skipped the cork roadbed and glued the track right on the foam. It lowered the track from the main a little and saved me time and money (for the cork). The end result worked fine for me. As for the sound....couldn't hear any difference.
Kevin
John P
31
Gary
I'm in the process of re-doing my layout, I'm using 2" foam on top of plywood and laying cork under the track, main lines & sidings, I secure my track to the cork and foam with 2" stick pins with a hook bent on the end which hooks on a rail tie, one on each side of the track opposite to each other at 8" to 18" spacing. This may seem odd and looks a little out of place until the pins are painted and track is ballasted but the big advantage is the ease of removal and flexible for future changes. I might have a problem with committing LOL :>)
Later
Dansco
101
Hey,
Iv not used cork, or any roadbed before, a few points came up that interest me.
First: Using N scale roadbed? This sounds cool to me, I like the lower profile in spots.. any one have any examples etc?
Second: How do most folks fasten the track to cork if its laid on foam? I assumed that just nails would be enough, but now Im uncertain....
Thanks
MasonJar
It's not rocket surgery
Oct 31, 2002
5,362
Ottawa, Canada
Dansco,
Nails are not enough - in fact they don't do anything to help the foam adhere to the cork. You should use an adhesive of some sort - latex caulking is good, as it accepts paint and can be "undone" if necessary. A thin layer is all that is needed. You can use pins (the long T-sheped type work well) to keep the cork in place while the caulking dries. Then you can glue the track to the cork using the same caulking - again a very thin layer.
Andrew
jmurphy148
Cape Coral, Florida
Foam source
Where did you get your foam sheet. I need a 4'x8'x2" sheet and can't find it anywhere locally. Unless of course I'm searching for the wrong thing. Neither Lowes or Home Depot seem to have it.
Help please,
John
MasonJar
Oct 31, 2002
5,362
Ottawa, Canada
John,
Sorry to be the bearer of bad news, but the stuff seems to be very difficult to find in warmer climes, especially California and Florida... I hope someone more local can point you in the right direction!
Andrew
Nomad
1,570
Elks Plain, Washington
There's a thread here somewhere about a gauger who found it in California under a different name or something. Maybe somebody remembers it and can point you to it.
Loren
nkp174
1,455
Cincinnati, O.
I've found that hand laying turnouts directly into foam is a nightmare. I'm never going to hand lay directly on foam again...the cork on foam worked 10x better.
For non-hand laid track work, I'd definitely use track directly on foam in many places...anywhere were the main lines are elevated.
MidnightRR
39
Denver, CO
www.midnightrailroader.com
Help please,
John
Unfortunately, it is much harder to find in warm climates like yours than where it gets cold. We can get it everywhere, including HD and Lowe's.
You might try Googling "Dow" or "Dow-Corning insulation dealer" or something like that.
Dansco
101
Thanks All,
It sounds that the gluing cork to foam and then glue track to cork is the best practice.
Any tips and techniques for building the layout "temporarily", fully testing the layout by running trains over grades, through turnouts and radii, etc. before gluing!
Thanks
Dansco
