Block Detection
Discussion in 'FAQs' started by CN1, Jun 12, 2005.
  1. CN1
    CN1 Active Member
    Any ideas how I can make "block detection" on the cheap? :confused:
  2. seanm
    seanm Member
    .......lets see.... You could put two VERY thin pieces of wire up through the track so they are almost touching eachother and just brushing the axels... when they touch, you would make a light flicker. Course you will really need to tune it so it does not knock the cars off the track.
    Cheap enough?
  3. jim currie
    jim currie Active Member
    how cheep ?
  4. CN1
    CN1 Active Member
    seanm, thanks
    How cheap? I don't understand the question: Cheap means cheap, el cheapo, scrooges, $0.01 etc...
  5. jim currie
    ok i understand you idea of cheep( to me cheep means less that retail) cant help you.
  6. CN1
    CN1 Active Member
    So unless you spend thounsands of dollars, you cannot have a functional block detection?
    I don't believe this at all
  7. Pitchwife
    Pitchwife Dreamer
  8. CN1
    CN1 Active Member
    Thanks for the links Pitchwife.
  9. Pete
    Pete Member
    I haven't checked on the cost to build them lately, but the Twin-T detection system designed by Linn Westcott in the late 50's is relatively simple, and there have been a few offshoots and improvements over the years. Peter Thorne describes them in one of his books, Easy-to-Build Electronics Projects for Model Railroaders
  10. kf4jqd
    kf4jqd Active Member
    I forgot where I got mine. I have to waite for my computer to be shipped to me. I baught IR senors for $10.00 ea.....maybe I can do a search.
  11. kf4jqd
    I found the link. He makes them per order. He's a Ham Radio Operator too that I have talked with him on the air. They are very simple to use. You can use them with Sunrise and NJ Internation signals. Others too. If you use lamps instead of LED's, you need to install a relay. Very, very, very simple to use. They are small enought to use on Nscale too.
  12. belg
    belg Member
    Andy I attempted three times to open your link and it timed out everytime, maybe its a Mozilla problem I'll have to try with IE later. Pat
  13. kf4jqd
    It works no problem here. Try copy and paste.
