BIGEST, FATEST motor for a wild dagger
Discussion in 'RC Offroad Forum' started by Matt Horton, Dec 24, 2003.
Thread Status:
  1. Matt Horton
    Matt Horton New Member
    I am thinking of building a new wild dagger chassis and I was wondering what is the biggest and fastest motor I can fit to the gearboxes without modifying them. I can use up to 24 cells, which have 28.8 volts. ESCs are not a problem.
    :D :) please help i am new :) :D
  2. timrock
    timrock Active Member
    http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXJA78&P=7
    i would get two of these motors.`best bang for you buck`
    you just need to set the timing on one of them to go in reverse.if you dont one motor will spin faster than the other and will take life out off them and the truck will run slower.but if you set it up right and run 12cells in series per motor,the truck will Haul A S S
  3. timrock
    NOTE:your truck requires two standard size motors for replacment.
  4. Matt Horton
    are u sure this motor would take 12 cells
  5. Matt Horton
    tim rock your rustler sounds kinde cool and fast 100mph hay, whatever
  6. SAVAGE123579
    SAVAGE123579 Member
    if you want a motor i have a trinity P2k2 pro modifed 17 turn motor brand new lmk
  7. Matt Horton
    no thanks i want some high voltage super fast motors
    anyone else have any ideas
    plaese .........
  8. timrock
    the best idea is to get what i suggested in the first place but if all you care about is speed then this is what to go for
    http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXDVD5&P=7
    you need two of these and must set the timing on one of them for reverse.
    with these motors and all those cells/voltage you want to put to it,your truck will be way to fast for you and will run for about a minute or so b4 the battries die.(i can tell you dont know anything about rc stuff and i assume you can`t drive good)
  9. Get a special made one w?as little turns as possible
  10. A J G 3 6 6
    A J G 3 6 6 Member
    Tim Rock..what does your rusty look like? Do you have pics?
Thread Status:
