Best way to transition from coe 100 to code 83
Nick8564
Best way to transition from code 100 to code 83
I want to know the best way to transition from code 100 to code 83. Thanks
brakie
A thin cardboard shim will work as well.Make it as wide as the track and the ballast will cover it.
Nick8564
If using the atlas rail joiners will i have to file the code 100 track to meet the code 83, and how does that cardboard shim work?
green_elite_cab
Keep It Moving!
you won't have to file any track. the transition joiner is alittle higer on one side ( to mate with the code 83), and a little lower on the other side. the Ties are actualy taller on code 83, or so i've heard. they should match up
