batteries
Discussion in 'RC Offroad Forum' started by bigsexy2177, Mar 5, 2005.
Thread Status:
  1. bigsexy2177
    bigsexy2177 Member
    why are the 3300 batteries better then the lower ones like the 1900's? do they have more power longer run time or what?
  2. gaz_r36
    gaz_r36 Member
    they last longer
  3. monsterrcbuilder04
    longer run time and more use out of them. if you plan on racing get them but the 1900 work fine bashing with me
  4. dj6666969
    dj6666969 Active Member
    another thing might I add that chargeing time will increase. The more MAh like 1900 MAH is alot less then 3300 MAH so the 3300 will take longer to charge. Depending on the charger most of them will charge larger size MAH batt's, other won't (i.e Duratrax Pirana peak charger)
  5. monsterrcbuilder04
    yes deffinatly check that your charger can charge the higher mah packs
  6. bigsexy2177
    bigsexy2177 Member
    what type of charger do u guys recomend?
  7. monsterrcbuilder04
    the mrc brain 959. thats a great charger
  8. redheat
    redheat Member
  9. dj6666969
Thread Status:
