Ballasting - one person's experience
rsn48
191
North Vancouver, BC, Canada
I am an N scaler, but have done all my ballasting on a friends layout, which is HO. I do not consider I am giving you the best technique, but I do know I am giving you the cheapest one that works.
Like many of you, I've had problems when ballasting. And, I've read lots of threads from folks who have had trouble ballasting. I ballast with a chap who is the "master"; he ballasts most people's layouts in our group of model railroading friends. He is also the best modeller, layout builder, etc of all of us. So last week we ballasted a new area on the Kettle Valley HO layout we were working on, so with all the problems I have read about and experienced, I watch him like a hawk. So I am going to give you - step by step - what we did.
First, you have to saturate the ballast. The level of "wetness" of the ballast is actually critical. You will notice I did not say wet it, but saturate it. So lets looks at the difference. Its summer and some one jokingly turns a hose on you and your jeans become wet. The water spreads out over the jean and you aren't dripping. Now the party continues and another friend throws you in the lake, now your jeans when you walk out will be saturated, can't hold any more water; and you are dripping. I will explain why this is important in a minute.
Now when spraying, don't spray directly onto the ballast, nor too closely to it or it will move and holes might form. You are trying to create a heavy rain with the sprayer, but that's it. So spray on the horizontal to the ballast, or slightly down towards it, but maintain your distance with the sprayer. The object is to wet it and saturate it.
What is in your sprayer is plain water. Now I know half the planet advocates "wet water" (water with a couple of drops of detergent in it), or an alcohol water mixture, or pure alcohol. So there I am spraying and I ask Mike how much detergent to put in the water. His response: "Rick, I stopped putting detergent in the water because I couldn't tell the difference when I added it and when I didn't. Since I couldn't tell the difference, I stopped adding it."
You will only want to spray three or four feet only, then move on after the glue/water mixture is eye dropper into the ballast. The mixture of white glue to water is 50/50. Again others will tell you to use matte medium, but the white glue water mixture has worked since the beginning of time. It is possible the earth is held together by white glue and water mixed together. Since this is the cheapest technique and it works, why muck with success.
This next part is important. You must establish a pattern of laying the glue down; its easy to miss a part. So I watched the master. First pass is the white glue/water between the ties, next pass is on the outside of the rail ties, next pass on the ballast beyound the rail ties, then lastly repeating this same procedure on the other side; so 5 passes in all - one in the middle, two on either side of the track.
We used kids eye droppers.
What I recommend, if you've never done this before is try an experiment on the first six inches you do. After you have done this experiment, it will be as though the scales fell from your eyes. For the first 6 inches, don't wet or saturate the ballast for the white glue/water mixture. Put on liberally some glue/water without any wetting agent. What you will discover is that the glue/water sits on top of the ballast without sinking in, also some ballast may float to the top of the glue/water bubble. Now with the glue sitting on top of the ballast, grab your sprayer and start spraying. You will find it takes a bit of spraying, but once the ballast really gets soaking wet, the glue/water will be sucked into the ballast.
When glue sits on top and won't go into the ballast, the ballast isn't wet enough.
Finally after the glue has dried, a day or two or three, go back and run your finger over all of it. You should discover that about 98 % of it is rock solid. You will probably run into a part that isn't securely glued and easily moves. So then you re-soak the ballast with water, then add your glue/water mixture again. And voilà your ballast will be glued solid.
billk
1,116
Marion, IA, USA
Good article, Rick. I might suggest that using "wet" water might make more of a difference with N scale, and also might be more necessary if you use ballast made from ground up walnut shells or the like vs. something made from real rock.
I've also found that using a small paint brush, dry, is a good tool for the final spreading of the ballast - between the ties, away from the rails, etc. Use a very light touch!
ezdays
Out AZ way
Feb 3, 2003
6,339
Arizona
bigbluetrains.com
Rick,
Thanks for the comprehensive step-by-step. I've just finished ballasting my N scale layout, my first. I've read the books and asked questions here, but there is nothing like doing it yourself to learn what works for you. I agree with your procedure, but I am one of those that advocates the use of "wet water" as well as a few drops of detergent in the glue/water mixture. The reason is surface tension. I found that even though the ballast is thoughly soaked, the glue will sit on top of the water and can cause the ballast to wash away. This, I think, is because of the the hardness of our water and the degergent helps break that surface tension created by this hardness. One other solution might be to use bottled water if you have water as hard as we do here, but I find a few drops of detergent is a lot more econmomical.
Just one thing to add to what you said. I bought both a basting syringe and a glue syringe and tried those in place of the eye dropper. The neat thing about using either of those is that they hold a lot more of the glue mixture and ballasting goes a lot faster.
Don
rsn48
191
I posted this write up in a number of different forums and a number mentioned the hardness of the water as a contributing factor for a requirement to using "wet water" or a water/alcohol combo. I would suggest to those who are nervous about the hardness of your water, to do the 6 inch test I mentioned above. If spraying the water on doesn't allow the glue/water combo to sink into the ballast, then move to "wet water" and if that doesn't work, then you might try a water/alcohol combo. I suspect that in 95% of all cases the water, or wet water will do it.
Drew1125
2,975
Hi Rick!
I do pretty much the same as you, except that I wet my ballast with rubbing alcohol, mixed with a few drops of black India Ink. This not only wets the ballast, but also gives it a little bit of a "grimier" look. But other than that, our methods are the same...50/50 white glue & water... (although, instead of an eye dropper, I simply use an old Elmer's Glue bottle...holds a lot more)
60103
Pooh Bah
Mar 25, 2002
4,754
Brampton, Ontario, Canada
Our LHS supplied me with a hair spray bottle (he collects them from his wife) that produces a fine mist. I now use this for wetting the ballast and other scenery materials because it doesn't blow things around the way the other spray bottles do. I follow this up by soaking with WS Scenic Cement (Matte medium). When I didn't wet the ballast, I found that only the surface layer was bonded and the bit underneath was loose. I apply cement to the ballast with an eyedropper and to grass and such with a sprayer.
RailRon
1,602
Trimbach, Switzerland
For applying wetted water I use a spray bottle I bought in a gardening shop. They called it a 'rose sprayer'. Its triangular bottle holds about one quart of water. On top is a pump with a pistol trigger mechanism, and you can adjust the water jet from a very fine spray to a real squirt. (Squirting works fine for washing down color on rock walls into cracks and crevices to enhance the rock structure.)
For the glue I also use an old bottle for white glue. However I always used to dilute the glue some more, about 1 part glue to 2 parts (wetted) water.
Charlie, thanks for the hint about adding some india ink. It sounds logical and I'll try it next time when I get to ballasting. :)
Ron
