Bad spot of track
Collyn
202
Canon City CO
www.rankinrevolutions.com
I can't figure why this piece of track keeps derailing all of my locos. It is a piece of sectional curve, on a flat spot in the layout and it keeps derailing all of my locos. there is nothing obstructing or close to the track that would cause it to derail and it is in gauge.
Ralph
Remember...it's for fun!
St. Paul, MN
I'm assuming that since its a piece of sectional track its a similar radius to other curved sections you have and not too tight a curve for your locos. Is the offending curved section the first one after a section of straight track? If so maybe your locos need an easement curve going into the turn. (?)
Ralph
N
nachoman
Also - look really close for a chunk of ballast or other obstruction next to the rail. Sometimes, the plastic tie spike is molded incorrectly and sticks up to high. Anyything between the rails is a potential culprit. I have seen track nails that work their way out and catch a coupler - causing derailment.
kevin
LongIslandTom
662
Long Island, NY
to Collyn:
How sharp are your curves? If they are 18"-radius and you are trying to run BIG locomotives like long 6-axle diesels, more often than not you will experience derailment problems, particularly at the rail joints where sometimes there is a kink, or if the rail joint has a sharp edge on the inside where it will catch a flange and throw it off the rail.
Also, if your curve leans outward, derailments are even more likely. Curves should lean slightly inwards.
Due to space constraints, I am forced to use 18" radius curves, and I also get a lot of derailments with long 6-axle locos like SD40-2s. I had to:
1 - Lay the curves using flex track to minimize joints.
2 - Make sure the joints that I cannot eliminate have no sharp edge or kinks.
3 - Superelevate the outside of the curve by shimming it with pieces of .015" styrene.
4 - Ensure my locos have free-swiveling trucks and that they are not warped, the wheels are in gauge and in good shape.
All these things together made my derailment problems virtually disappear.
Hope this helps!
