b-2 spirit
Discussion in 'Aircraft & Aviation' started by NULLMOON, Apr 1, 2007.
  1. yaniv
    yaniv Active Member
    for sure my friend but i need to got the book first :p
  2. MOS95B
    MOS95B Member
    I've got that book. I don't have the info you asked for at the moment, but I will look into it when I get home.
    It is a really nice book, though. I hate to tear it apart...
    There was a thread about it a while back. Alledgedly, the models aren't the best as far as detail and alignment.
  3. Bengt F
    Bengt F Active Member
    'Classic Paper Planes' and 'Historic Paper Planes'
    I don´t like taring apart my books either - so I only very carefully loosen the pages from the binding that I need for a model, scan them in high resolution, and put them back in again. In this way, I do not have to follow the die-cutting, which in some instances in my books is not perfectly aligned or centered.
    There is also the possibility of changing the size and scale if you scan the models, plus you have a choice of paper surface and thickness. And, best of all: just printing out a new part if you should happen to cut or destroy one . . .
    Bengt :smile:
  4. MOS95B
    MOS95B Member
    That's the plan, Bengt. Eventually. I've always been a bit of a book collector, so even removing the pages just feels wrong... ;)
  5. Bengt F
    Contents of 'Classic Paper Planes' and 'Historic Paper Planes'
    Sorry Yaniv,
    I didn´t read your post thoroughly. These are the models in the two books:
    In 'Classic Paper Planes':
    1. The 1912 Blackburn Monoplane
    2. The Morane-Saulnier Type N "Bullet" Monoplane - French WW I Fighter
    3. The (all-red) Fokker Dr. I Triplane Nr. 425/17 (Manfred von Richthoven)
    4. The Fokker E.V/D.VIII "Flying Razor" Parasol Monoplane WW I Fighter
    5. The Siai-Marchetti S55 Flying Boat
    6. The (well-known) Ryan-NYP "Spirit of St. Louis" (Capt. Charles Lindbergh)
    7. The German Schleicher Rhönadler Glider
    8. The Fairey Long-Range Monoplane
    9. The Avro Type 560 monoplane
    10. The Hawker Hart Biplane
    In 'Historic Paper Planes':
    1. The Gloster "Gladiator"
    2. The Hawker "Hurricane"
    3. The Mitsubishi "Zero" Japanese WW II Fighter
    4. The Messerschmitt BF-109e German WW II Fighter
    5. The Fairey "Barracuda"
    6. The Boeing B.52 "Superfortress" Bomber
    7. The Lockheed U.2R
    8. The Northrop B-2 "Spirit" 'Stealth' Bomber - the subject of Nullmoon´s thread!
    All the best from
    Bengt :D
    Edited in: If carefully built and with a proper nose weight (levelled at the wing CG), these models are also able to really fly - they are all 'flyable' models! However, I am not so sure I´d like to try with an original model. A word of caution: these models are not intended to be built with internal formers - I have thought about adding at least some. Perhaps I should try flying with a scanned one, though . . .
  6. MOS95B
    MOS95B Member
    I have "Historic".... So I may not be much help after all....
