Avia B534 in 1/48 scale.
Discussion in 'Internet Finds' started by cecil_severs, Jan 18, 2005.
  1. cecil_severs
    cecil_severs Member
  2. cardfan
    cardfan Member
    Are you sure about that link? When I click on it I go to my own album, which depresses me because I see projects I haven't yet finished...
  3. NOBI
    NOBI Active Member
  4. bfam4t6
    bfam4t6 Member
    That is some great work so far Cecil. I'm looking forward to the rest of the build.
  5. cecil_severs
    cecil_severs Member
    Thanks Nobi for catching my link error. Of course it worked perfectly when I tested it,...duh. I'll post the rest of the pics here.
  6. cecil_severs
    cecil_severs Member
    Here are some more pics for this build.
  7. barry
    barry Active Member
    Looking good like the trick with the gun ports.
  8. Scorpio
    Scorpio Member
    Hello Cecil
    A very much nice and very clean work!
    But I have a question: what does signify "X"?
  9. shrike
    shrike Guest
    The "X" is the Bulgarian national marking
  10. cecil_severs
    cecil_severs Member
    I'm posting some pics now of my adventure in airbrushing for the underside of this model. Let's just say that the overall result was not pleasing. Viewer discrection advised for the following pics as graphic depictions of model destruction are shown.
  11. cecil_severs
    cecil_severs Member
    All is not lost though I did spend most of Sunday re-printing parts and re-skinning the entire outer fuselage. The results were worth it.
  12. bfam4t6
    bfam4t6 Member
    Great work Cecil. I admire you at least having the courage to try something like airbrushing. I suppose you did know that you could reprint the parts, but for me, I dare not be too adventerous(sp?) becuase I know that I am very talented when it comes to destroying a model and only slightly talented when it comes to making one look good. The seems though look fine. I can't even tell that it has been reskinned. When you consider the size it's almost expected to have such seems. I'm sure your work and the rest of the detail will easily takes ones eyes away from them. And hey, if you want to see seems, look in my album :lol: I still look forward to seeing more! :D
  13. cecil_severs
    cecil_severs Member
    Here are a few more progress pics.
  14. cecil_severs
    cecil_severs Member
    And a few more pics.
  15. Leif Oh
    Leif Oh Member
    Cecil - great work not abandoning the project but mending it. I've been there, with the "sanding to within an inch of destruction", but never got to the stage of reskinning. How do you do that - another layer on top of the first? I think this experience needs to be told in more detail. Many of us would benefit. Thanks!
    I also like the wing spar. Nothing like getting a good stiff spar to determine and fix dihedral (or lack of it). Double bamboo sticks is it? - L.
  16. cecil_severs
    cecil_severs Member
    The "re-skinning" is done using a fairly thick paper (about 40 pound stock) not card stock. I print a slightly larger copy than the original and then trim or sand as required to get a pretty good fit. This actually makes a very strong final product since it consists of several layers. The bamboo spar is a single skewer shaved flat on two sides so that it slides through the square slot in the fuselage.
    I'm thinking that a similar skinning process may help you with the very large wings on your Airacobra project. Of course you will want to sort of reverse the process to protect your valuable printed parts. First contstruct a "white wing" from parts cut slightly smaller than your printed ones. Then construct the wings with whatever formers and spars you deem necessary with the white card pieces. The printed wings should be printed on light card or heavy paper and "skinned" onto the completed wing. That way you can experiment till you get something you like before committing to the final product.
    Actually I just want to see more progress pics on your fabulous project.
  17. Leif Oh
    Leif Oh Member
    So I'd better get my butt home from the office and get going then! Thanks - L.
  18. Jim Krauzlis
    Jim Krauzlis Active Member
    Oh, that's beautiful work, Cecil! :D
    You've done a brilliant job on this plane, a very clean build!
    Great photos, and hope you are able to post more soon. :wink:
  19. cecil_severs
    cecil_severs Member
    Progress on this project continues to be very slow but I'm having a lot of fun with it.
  20. Leif Oh
    Leif Oh Member
    Looking very good - what a save! O-rings are marvellous, aren't they. In 1/48 there's a very good selection of them; more difficult in 1/25 and larger. - L.
