Atlas HO tuntable conversion
Discussion in 'N / Z Scale Model Trains' started by Dorcas, Sep 24, 2003.
  1. Dorcas
    Dorcas New Member
    Atlas Turntable, has any body tried to change an Atlas HO turntable into an N scale one? So before I operate on my brand new HO table some advice is needed. By the way I will be using Atlas code 55 track
  2. Vic
    Vic Active Member
    Hi Dorcas, I guess you are wanting to convert the Atlas turntable to N scale because you like the pre-set stops. That's gonna end up being one huge turntable in N scale.
    Since the Atlas table is designed to be mounted on top of the table my thought would be to mount it under the table and use it to drive (thru the table) a smaller scratch built table or platform on the top of the table.
    But....those preset stops are going to be way too wide for N scale I would think and I don't believe there is any way to change them.
    If you like the idea of a surface mounted turntable like the Atlas it would be a simple matter to scratchbuild something similar in N scale driven by a 1 RPM motor mounted under the table.
    Just some thoughts.
