Atlas code 55 turnout machines
Discussion in 'N / Z Scale Model Trains' started by guyvanwettering, Jun 5, 2007.
  1. guyvanwettering
    guyvanwettering New Member
    I need to know if the Atlas deluxe under table switch machine is worth looking at to use on my layout. My benchwork consists of 3/4" plywood and cork roadbed. Any opinions on this?
  2. Nomad
    Nomad Active Member
    The under table machine is a regular ho gauge Atlas switch machine with a different throw bar. The deluxe machine has contacts added for power routing and such.
    I have always had good luck with Atlas machines, but they cannot handle constant power, or they burn up. The controller that Atlas makes is a momentary contact slider for that reason.
    I have 4 on my layout now and have had no problem.
  3. guyvanwettering
    Thanks for the reply, grewsome. I have a toroise machine and it works well, but I can't seem to get over the price. It may not be too bad for a layout that has a few turnouts but when you get to over fifty, a few dollars each here and there adds up. I don't mind if the turnout snaps in place as opposed to slowly moving over. If you think about it there is alot more mechanically going on with the tortoise versus the atlas. Fewer parts usually means fewer problems.
  4. Nomad
    Nomad Active Member
  5. guyvanwettering
    Thanks, I've thought about manual control but I want to be able to build a type of central control panel for turnout control. Later maybe integrate them into my DCC system. There was another website that I seen a modeler use slide switches with linkage to operate the turnouts. Looked very neat and you can get those type of switches at radio shack alot cheaper than a house type switch. Also the slider switches can be bought with double pole double throw configuration which gives you an extra set of contacts for signaling or whatever you choose.
  6. Boilerman
    Boilerman Member
    I am not one that advocates the use of E-tailers but if you shop them you can find The Tortoise actuators for a lot less (especially when you purchase them in lots of 12 or more) than what the LHS's sell them for.
    I have used the Tortoise's since they came out and have yet to have one fail over the years, plus they have the required contacts for powering frogs on the Atlas code 55 turn-outs.
