Athearn Mikado derailments
sumpter250
multiscale modelbuilder
cidchase,
Thanks for the link. If you can respond on that forum, there was a comment on "surging", and a clicking sound. I had that on the chassis I used for the On30 2-8-2. It finally showed up. The gear on the main driver was cracked. It let go alltogether, and had to be replaced. I Emailed Athearn, and got the new part in the mail.
The removal of the heat shrink will help the "derailing" problem. and trying to balance the loco weight will help. As built, the Athearn Mike balances on the # 3 driver. It would run better, and pull better if the balance point was closer to the #2 driver.
Pete
cidchase
Hi Pete, and Thanks
I infer from what you say that the drivers are numbered from front to back, which makes sense, but just checkin'. :D
sumpter250
Cidchase,
OOPS, there I go with the "common Knowledge syndrom" again. Yes, the drivers are numbered from front to rear.(within the engine. A mallet would have two #1 drivers, a triplex would have three)
Pete
