Aristo Craft Lil' Critter
Discussion in 'G / O / S Scale Model Trains' started by woopud, Jan 20, 2006.
  1. woopud
    woopud New Member
    f i would to buy the AristoCraft Lil' Critter as a starterset for outside can I hook up a heavier power supply and still use the standard train engineer remote ?
  2. Carl
    Carl New Member
    I have a Lil' Critter that I run using the Aristocraft Ultima powerpack, using the Aristocraft Train Engineer Radio Controller. The Train Engineer is the one that Aristocraft recommends for large scale use. You do not want to use the Train Engineer that is for HO Scale. Hope this helps.
  3. Philinbos
    Philinbos Member
    We use the Aristocraft 10 amp transformers for both our outside and modular layout with the train enginner. As you explain your use, the output voltage is the important factor for you - not the Amps of your transfomer...
