Aricraft Stand
Discussion in 'Aircraft & Aviation' started by wyverns4, Sep 15, 2006.
  1. wyverns4
    wyverns4 Member
    Does anybody have a file or a website for a simple aircraft stand? I'm looking for one like used to be included with old 1/72 scale kits, you know, "V" shaped base with a swept pillar to attach the plane to.
  2. 72BMWR75/5
    72BMWR75/5 Member
  3. cgutzmer
    cgutzmer Guest
    I know exactly of what you speak :) I am fairly certain I have a download of one somewhere but I wont be back to work to check til monday. I will let you know then if someone doesnt hook ya up sooner.
  4. Stev0
    Stev0 Active Member
    Would'nt a coat hanger setup be better? It would'nt be so prominent.
    A little bending and a little soldering and voila!
  5. Texman
    Texman Guest
  6. sjsquirrel
    sjsquirrel Member
    Here's one I whipped up for Bill Jone's Arrow model. I created it manually in an OpenOffice Spreadsheet that you can download here and modify to suit your needs. A PDF of the stand pictured below is here. I've since created this stand in Meta and Pepakura but haven't finished test building and everything. If you're interested let me know.
  7. davis4559
    davis4559 Member
    I created on for my X-33 build
    Let me know if you have any question on buiilding it
  8. wyverns4
    wyverns4 Member
    Thanks Everybody for your help. As you can see, several of you gave me some great ideas' I will use the "coat hanger" idea for another project!
