ANY TA04 CHASSIS PICTURES?
Discussion in 'RC Drifting and Setup' started by nekmiyevo2, Apr 11, 2005.
  1. nekmiyevo2
    nekmiyevo2 Guest
    are there any TA-04 parts that are not blue?
    I want to built a TA-04 that looks all silver or black with fully upgrades
  2. rcdrifter
    rcdrifter Guest
    The TA04-TRF, which was a special edition ta04, came with upper and lower silver chassis parts.
    [​IMG]
    [​IMG]
  3. SpArKeY_STi
    SpArKeY_STi Guest
    or anything anodized you dont want that color, you can de-anodize and rattle can them. And with the chassis you can just rattle can those too.
  4. nekmiyevo2
    nekmiyevo2 Guest
    how can I de-anodize them?
    thanks
  5. rcdrifter
    rcdrifter Guest
    If you really want to deanodize something the easiest way is to stick it in the oven for about 5 min get it really hot then spray down with Easy-Off Oven Cleaner..
    DO NOT DO THIS AROUND FIRE OR THE OVEN AND PLEASE READ THE EASY OFF INSTRUCTIONS AS THIS WILL AND CAN BE A DANGER!!
  6. nekmiyevo2
    nekmiyevo2 Guest
    for how hot?
    what color will it become after? silver, right?
  7. nekmiyevo2
    nekmiyevo2 Guest
    does it usually work?
  8. SpArKeY_STi
    SpArKeY_STi Guest
    If it didnt work, we probly wouldnt tell ya.
    I believe the temp is 450. But dont quote me on that.
  9. 90 degrees
    90 degrees Guest
    im new and i need help
    yo im new at this site and i want to no how do i post some picks of my car... help please
  10. 90 degrees
    90 degrees Guest
    that car is sick i been wanting to get one...does it drift well
  11. 90 degrees
    90 degrees Guest
    thats a sick car i been wanting to get one but i didnt no how well it drifts..does it drift good
  12. SpArKeY_STi
    SpArKeY_STi Guest
    Host them threw your own website, or a picture hoster such as Imageshack.us, then copy the URL and put it in the code
  13. SpArKeY_STi
    SpArKeY_STi Guest
    Its usually not the car as to how it drifts in my experances. Its mostly set up, and how much torque you have to the motor and such.
  14. 90 degrees
    90 degrees Guest
    true u have a point
  15. nekmiyevo2
    nekmiyevo2 Guest
    so where can I find the piant and the cleaner stuff?
    how much?
  16. SpArKeY_STi
    SpArKeY_STi Guest
    Paint and cleaner... theres nothing speical about them. You can get them anywhere that sells rattle can paint (AKA Spray Cans) and cleaner stuff is at a Walmart or Kmart or such. Check your LHS if you want Special Annodize paint, or towerhobbies.com has it i believe.
