Any one own a
nolink5750
Woodland Scenics Low Temp Foam Gun? I've had this thing plugged in for an hour and ever 20 minutes or so I get 1 drop. Does this sound defective maybe?wall1 I pull the trigger and nothing... maybe a drop.
nolink5750
Man do I feel stupid. I never used a glue gun before. I put another stick in behind the one that was in there so now when I pull the trigger it is feeding it's self and working great.sign1 Live and learn I guess. The problem now is it is setting up to fast for laying track on the foam bed.
nolatron
Hah. Glad you figured it out.
But yeah, when a stick gets low it goes past the the little feeder clip, so a new stick needs to be inserted so it'll continue to push what's left through.
PWRR-2207
Rogue Islander
Glue gun...
And be careful when trying to feed the new one in with the trigger - I have had to push the pins out to reconnect the trigger to the spring because I tried to force it...
TCH
make sure you wear a rubber glove
that glue gets really hot and sticks to fingers very well
nolink5750
Starting to find out how his works. Got myself a pop sickle stick to spread the glue. Working good so far.
Go slow and easy.... wow
