Any issues with the terrestrial voyager??
Discussion in 'Science Fiction & Fantasy' started by jleslie48, Apr 8, 2008.
  1. jleslie48
    jleslie48 Member
    I'm getting a build report with a problem, anybody else run into this issue:
    I started assembling the skeleton, and the main spine
    and bulkheads seem to be in different scales--a big discrepancy in
    sizes. Several mm for bulkheads A and B--as far as I got.
  2. Jim Nunn
    Jim Nunn Member
    A little more information Please.
    What model are you building, is it a commercial kit or a down load. Are you building from a scanned copy of the kit?
    Jim Nunn
  3. SCEtoAux
    SCEtoAux Member
    Jim, he is asking about the Terrestrial Voyager model found at the bottom of this page
    Lower Hudson Valley Sci-Fi models
    I have not started on that particular model yet. It is in the (ever growing) queue.:eek: :mrgreen:
  4. gippolot
    gippolot Member
    Yes, the original PDF files I released are incorrect.
    My original drawings were single page AutoCad files, then converted to Tiff files, coloured, then to single page PDF files. All these were correct.
    The problem occurred when I finally combined the single, separate PDFs files into a one combined PDF file.
    PDFCreator changed the page sizes from 8.3 x 11.7 inches to 8.5 x 11.0 inches. I hadn't realized this.
    Since then I've found, and used FreePDf XP to convert the single pages to a combined file. And it doesn't change the page size. I only checked the single PDF files, not the combined files.
    Again, apologies for the problems.
