Another turntable ???
shaygetz
3,612
www.freewebs.com
Welcome to The Gauge, Joe:wave:
As I go thru and catalog my magazines I'll keep an eye out for you. The two simplest I've seen are one that uses a 1/4" stereo headphone jack and socket for the manual turn mechanism and wiring. The other used one of those lazy susans found in a kitchen cabinet. The bottom moved with the table itself but it was pretty clever none the less.:thumb:
Skammer
I have a Walthers 90' turntable that's never worked as well as I would hope - the mail problem is that power is supplied to the tracks via a set of brass wipers, which seem to conduct only about 50% of the time. I've been thinking about replacing the stem of the turntable with a 1/4" headphone jack (I think mono would work; wouldn't need to be stereo) which would allow it to spin and maintain electrical contact better. I haven't gotten to it yet, but I might tackle it when my passenger station is done.
Sorry, that's more of a kitbash than a scratchbuild, but there you go. I'll be following this thread for ideas though.
Don
10
If you can find them, the 9 thru 11 1957 issues of MR had 3 pt. article by Gordy Odegard on bldg a "modern" 3 pt. TT. Even if you don't build it, there are a lot of good ideas in the article.
Don
eightyeightfan1
Now I'm AMP'd
Torrington, Ct.
I replaced the wipers on my turntable with wires soldered to the rails. Something told me to scrap the wipers.
Skammer
How do you keep the wires from getting twisted as the table rotates?
Skammer
The Model Railroad Craftsman magazine that arrived in my mailbox today (April issue, I guess) has a nice article about scratchbuilding a turntable. I haven't read it yet, but it looks like it would be worth reading carefully.
webmaster
155
Surrey, UK
www.budgetwebsiteservices.co.uk
Skammer said:
The Model Railroad Craftsman magazine that arrived in my mailbox today (April issue, I guess) has a nice article about scratch building a turntable. I haven't read it yet, but it looks like it would be worth reading carefully.
Was the article any good? Is there anything you could put on here that wouldn't infringe any copyright laws?
We don't get that mag in the UK :cry: (Or if we do, I've never seen it).
Im going to be making a very small turn table for the Yo-Yo.
Skammer
Okay, I mistyped the name of the magazine - it's Railroad Model Craftsman. The article is by Trevor Marshall and called "Scratchbuilding a Quarry Turntable." He built it in On24 scale, but you could easily adapt his methods for HO. You would also want to make the bridge longer; his is only 38 scale feet in O, which is still only 76' in HO.
Basically he made the bridge by soldering together a brass frame (to prevent warping and sagging) and then covered it with a wood deck/sides. The turning mechanism is built around a 1/4" mono phone plug mounted in a stryrene frame. The plug is used both to allow the table to rotate and to feed power to the track on the bridge.
The the motor turns a nylon gear that is held against a larger gear mounted on the stem of the turntable. The gears are held against each other by a spring, which allows slippage to prevent binding. The turntable is not indexed (the author only has one lead track anyway, and the motor turns slowly enough that indexing is not needed).
You can probably order a copy of the April issue directly from the publisher: http://www.rrmodelcraftsman.com/.
doctorwayne
3,516
Canada, eh?
I scratch built my turntable, but it's an Armstrong model (no motor). I didn't use any plans, it consists of some Atlas bridge girders mounted to a block of wood. I originally mounted an old electric hand mixer under the layout and had planned to turn the motor with a hand crank extending through the layout fascia. The bridge is mounted on one of the beater shafts. Because it's very close to the edge of the layout, I eliminated the mechanism and opted for "big finger" operation. Power for one bridge rail is provided by wipers under the layout contacting the beater shaft, the other is powered through the pit ring rail via wipers on the table wheels. Indexing is by eye.
I'm not sure if the speed of a prototype turntable can be regulated, but I have seen one operate so quickly that the diesel that was being turned actually rocked when the table stopped. It looked very unprototypical.
A very good, but pricey, rtr turntable is offered by Fleischmann, complete with indexing. For kits, Diamond Scale, also expensive, will build into a nice model if you don't mind correcting some minor design problems. Their indexing system is also pretty good, with the bonus that you can set it up at whatever intervals you require.
Wayne
