Another Fokker Dr1
Discussion in 'Aircraft & Aviation' started by cmdrted, Feb 23, 2007.
  1. cmdrted
    cmdrted Active Member
    Thanks guys, I always wanted to build one of these multiwingers. I usually went with WW2 or greater aircraft but seeeing some of the work here made me take the plunge. The next bit was realatively easy, skinning the fuselage framework. It consists of 5 pieces which practically fit perfectly. I have to hand it to the designer on that one, which happens to be Pawel Mitewicz, the same guy that did the Me-109G from Maly. Mike Krol was right, his kits are a pleasure to build!
  2. Gil
    Gil Active Member
    You can play Red Baron with this one but you'll need an adversary for the other hand for a truly memorable experience...,
    P.S. This type of play can only be done in a safe room with a locked door and by yourself. Prevents being carted off in straight jacket to another type of safe room that doesn't have any toys...,
  3. Bowdenja
    Bowdenja Active Member
    Hey Ted............. I hear ya on the Tri-plane.......... I did one for the same reason:grin:
    As far as an opponent............ sopwith made a triplane too! Not much rigging on it etiher Ted:grin:
    Ummmmmm Gil.......... sounds like you had to do some explaining once before!:roll:
  4. cbg
    cbg Member
    I was pleasantly surprised how "easy" it was to build my first biplane. What's nice about the Dr.I is no bracing wires between struts (save for control cables).
    I imagine Gil and Eric have plenty of tips for stacking those wings the right way. . .I made a little temporary cardboard jig to help maintain spacing and alignment.
    I also have this kit, so I'll watch your build with interest. Thanks!
  5. rlwhitt
    rlwhitt Active Member
    Great work as always Ted! I noticed you commented on the fit of fuse skins, has the rest of it been good as well? I know the fit on old Maly's was pretty bad, wondering if they are pretty safe now?
  6. cmdrted
    Gil, have an adversary in mind, same company, Roy Brown's plane. Also what's all this about locked rooms? I just "hide" in the basement until all is clear. Rick, the fit on this is fantastic, Halinski worthy. I wonder if there is a way to get a listing of all the models this Pawel guy has designed, it would be worth getting.
  7. rlwhitt
    You know, I stumbled onto a web site recently that had information about designers of published kits. It was some sort of massive card model database. Really cool. I know I probably saved the link somewhere, but I'll have to check 4+ computers to see where it is...
  8. dfarrell
    dfarrell Member
    after seeing your cockpit pictures yesterday, I had to borrow your ideas for making the gauges and use it on mine. (I hope you don't mind. .) It worked out pretty good. It is kind of fun to watch someone else building the same kit. You can bet I'll be watching pretty close to see what else you come up with!:-D
  9. rlwhitt
    Ted, I found that database site link, and they show 33 models by Pawel Mistewicz. This site is pretty cool. Might just have to sign up to be a member!
  10. cmdrted
    Kool list! Thanks. I looked up this designer and he seems to have done a wide range. I remember alot of the kits he did for Maly, haven't built all of them yet.
  11. EricGoedkoop
    EricGoedkoop Member
    Squint, clench your teeth and mutter.
  12. cmdrted
    I think I have a single malt sitting around somewhere, thanks for the advice!
  13. Gil
    Gil Active Member
    Wing Mounting
    Try wire pins on the struts and matching holes drilled in the mating surfaces. This will limit the problem to getting the next wing onto the pins and aligning it correctly. It takes a little longer (as usual) but the angst of multi-wing assembly is reduced to a pleasant experience of stacking them up...,
  14. Mindaugas
    Mindaugas Member
    Aaah, I remember this model :) Yours is looking very very great! Gil, have you seen my fokker? It should be in this forum somewhere. I love how you did instruments. I left them "thin" :)
    Moreover, I know a nice gallery with hundreds of quality models :) - hehe, its nearly the same name as rlwhitt provided, but it is a different site! (click " galerie" )
  15. cgutzmer
    cgutzmer Guest
  16. cmdrted
    A bit of slow progress.
    It has been quite a few days inbetween building. I just managed a few things for today. The first was building up these skinny WW1 tires. I used the old stack 'em and chuck 'em in the dremel and they came out pretty good. Here they are built up with the covers front and back...
  17. cmdrted
    The other small bit of progress was the tail surfaces. Once again this is not your Father's Maly! This kit comes with separated control surfaces. The big PIA was rigging the control lines. It was'nt difficult to thread them thru, it was tough to get the slack out! I used @3lb fishing line painted black. Here's the topside view...
  18. cmdrted
    And the underside, showing the rudder control and stab control lines, and the built up tail skid. enough for one night, hope to be back to it in a couple days...
  19. cgutzmer
    cgutzmer Guest
    Looking great commander! I cant wait to start in on a plane again :D
  20. Jim Krauzlis
    Jim Krauzlis Active Member
    Looks to me like you got that control rigging just right!
    As always, a joy to behold your build, Commander!:grin:
