Discussion in 'Photos & Videos' started by Les, Feb 2, 2005.
  1. Les
    Les New Member
    I have some plastic HO picket fencing I want to fix to my project. Not exactly a large base in which to apply adhesive to so has anyone out there got the name of 'the' product to end all products that will anchor this item permanently. Cheers:wave:
  2. paulherman
    paulherman New Member
    I expect a little white glue would do as well as anything - but you might have to prop it up while it dries.
  3. CalFlash
    CalFlash Member
    I would use something tackier like a contact cement (test it for reaction with the plastic) or adhesive caulk. I just got done laying 300' of flex track using adhesive caulk and it sets fairly quickly but with some working time.
  4. Russ Bellinis
    Russ Bellinis Active Member
    Heat some pins with a bic lighter or a soldering tool and when hot enough, push them into the bottom of the fence posts. Then using a pair of wire cutters (made for steel, not rail nippers) cut off the heads of the pins. Now just drill holes in the scenery base where you want the fence to put the pins into.
