ACTRR my be dismantled and re-constructed
Discussion in 'N / Z Scale Model Trains' started by fifer, May 16, 2009.
  1. fifer
    fifer Active Member
    I know the ACTRR is very very near completion but I have made a large error in the construction.
    We have a lot of people stop to look at it and it is a great layout BUT , there is confined space for operators and visitors.
    I am also thinking of double main line and the use of Kato Uni-track.
    If I proceed with this I will rescue all the structures and try to re-use what I am able to. The layout was designed for switching and that never happens so new layout will have minimal switching and bi-directional mains. My helix works perfect but will go as well (it is a space monster).
    Right now I am in the thinking stage and working on a plan of some sort.
    It is tough to give back real estate but it has become an issue having the shop and friends over.
    Mike
  2. fifer
    fifer Active Member
    Today I removed all the rolling stock and locomotives and boxed them all back up so a portion can be sold off.
    The skirting was almost all removed and Robins doll molds were taken out from under the layout.
    Then all the people , autos , and some of the structures were removed.
    Tomorrow I will take the remaining structures off and maybe the facia will go next.
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Funny how it tears down so much faster than it goes in.
    Mike
  3. KATY
    KATY Member
    Mike, hope your new layout will please you. Must be hard to do with so much work that must have been put into your present layout. I can understand however, since I disdain switching and just like to see them roll. A double track main will be just the ticket.
    Jack (Katy)
  4. fifer
    fifer Active Member
    Thanks Jack , I think we all get to a point and realize , if we finsh , what will we do next.
    I guess if we had unlimited space we would have unlimited work.
    Mike
  5. fifer
    fifer Active Member
    Today I got all the facia off and almost all electronic devices removed. Then started on the tree removal and the remaining drive-in , turntable , roundhouse , repair shed , and 2 houses as well as the river bridges. I then moved on to the scenery over the helix and on around to the other side of the center loop. This is all the scrap my S10 could hold. so done for today. I now need to see where I may be able to get Homasote around here.
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Mike
  6. fifer
    fifer Active Member
  7. fifer
    fifer Active Member
    Here is the progress as of today. It is down to the bare risers. Tomorrow it will be re-habing the backdrop and removing the the yard benchwork and the helix benchwork.
    [​IMG]
    [​IMG]
    Mike
  8. TrainGuyRom
    TrainGuyRom Member
    Whenever I hear about a layout being dismanteled I get so sad.
    Some people do that when they have nothing else to chang on the layout and just tear it down & start all over again.
    I hope your next layout will be even better
    TGR
  9. fifer
    fifer Active Member
    Thanks TGR , I am excited!!!
    Mike
  10. fifer
    fifer Active Member
    Here is the finished layout design. The city will be on the left end and mountain with lake will be on the right side over most of the double loop and the track at the back of the long section will be elevated about 2 1/2". The loop on the lower left will go into the wall and be visable from the outside via a window that can be opened for access and will feature a tunnel lining even though the inside of the room will be buildings.
    [​IMG]
    Mike
  11. Trainiac77
    Trainiac77 Member
    Looks like a fine layout. What did you use to do the drawing? I am doing a N layout with Kato Unitrack as well and would like to get my ideas down on paper before I start laying track. Thanks in advance!
  12. fifer
    fifer Active Member
    Trainiac , I used a program called AnyRail. I have had some computer locking problems with the program installed though but program is easy to use.
    http://www.anyrail.com/index_en.html
    Mike
  13. Trainiac77
    Trainiac77 Member
    Fifer, Thanks for the info. I downloaded it tonight and it seems to work fine. Now I just have figure out how to use it!
  14. fifer
    fifer Active Member
    I would recommend you open the tutorial in another window and shift back and forth for answers. It is really straight forward.
    Thanks , Mike
  15. fifer
    fifer Active Member
  16. steamhead
    steamhead Active Member
    Well Mike...Didn't take long after putting the wrecker ball down to get started on the new version...!! Good for you...(and us..).
    Will look forward to your updates on the new ACTRR....:thumb:
  17. fifer
    fifer Active Member
    Thanks Gus , good to hear from you!
    Mike
  18. fifer
    fifer Active Member
    HAPPY FATHERS DAY !!!!!!!
    Here is the last two days progress on the ACTRR.
    I got all the homasote down and trains temporarily running on both mains all the way around.
    I plan on working on the yard today and try some different configs.
    http://www.youtube.com/watch?v=Y8j-1u52X4I
    Mike
  19. Boilerman
    Boilerman Member
    Mike,
    First of all Happy Fathers Day and second I checked out your latest video and really like what you are doing, that new layout track plan looks to be very clean and will posses a lot of running with the 2 main lines and it looks like you have achieved the space you wanted for visitors to view your work and still have plenty Railroading.
    Keep the photos and videos coming!!!!
  20. fifer
    fifer Active Member
    Well , here is what the final plan turned out to be. The track is all in and wired up and pinned down in final position. I will try to post Video #4 later today as well.
    [​IMG]
    Mike
