? about fast track cross overs
Discussion in 'G / O / S Scale Model Trains' started by ozzy, Jun 10, 2007.
  1. ozzy
    ozzy Active Member
    now can i use one so that 2 different trains on there own transformers ? so i can have a train cross a nothers path?
    this will not be for main line track. but in a yard. or a siding crossing a main line.
    i need a way to let my mainline train on the inside line cross the other line to a yard on the outside.
  2. Greg Elems
    Greg Elems Member
    Hi again ozzy. I took an old Marx 90 degree crossing and modified it to do exactly what you are talking about. It might be easier to dig it out and shoot a picture of the back side than explain the cuts and re-solder job I did. One thing about it, when I used it in a figure 8 it worked fine and if I used it for crossing two separate loops it worked that way too. So yes it can be done and if you have an old one to experiment with give it a try.
