A virtual branchline
Ralph
Remember...it's for fun!
St. Paul, MN
I have a steel mill on my layout with a blast furnace that isn't really served by sidings. It rests against the backdrop so its suggested that the track for coal and ore cars lies behind it. I thought it might be fun to support this concept with a visual so I constructed a highline that travels along the backdrop and appears to duck behind the steel mill complex.
It starts in a corner of the layout with a real HO engine and cars. The second hopper is cut at an angle so it seems to travel into the backdrop.
Ralph
St. Paul, MN
To get the train into the backdrop I placed some cars on my scanner and created slightly smaller paper replicas to convey the illusion they were a little farther away. I also scanned a bridge for them to roll over and disguise the wheels which scanned poorly.....the highline is routed between buildings in the foreground and background of the backdrop
Ralph
St. Paul, MN
...a little further down the line just before reaching the steel mill....
I positioned the cars with spray-on adhesive that allows items to be removed in case I decide I don't like the idea afterall. I'm leaving it alone for a couple of days to see what I think....
Ralph
MCL_RDG
851
S.E.PA.
Ralph...
...my dear darling boy- You have it backwards!!!
Your supposed to have the train in front and the Blast Furnace as the backdrop.
Now don't be upset with my comments. I am enthralled with the PC loco and READING coal cars- truely I am~~~~~~~~~~~
I am doing PC/RDG
But, you leave me perplexed. I am inna quizzle over this puzzle. I'd run the rails right up and say, "Load 'em"! (Even if ya hafta cut the Blasted Furnace in half and make it twice as long or half as deep or both).
Uh, I faint with the thought.
Mark :( :confused:
Ralph
St. Paul, MN
Hee-hee, Mark instead of modeling the blast furnace operations I went for the rolling mill pictured below. I just didn't have room to put together a blast furnace scene that I'd find convincing.
Ralph
Ralph
St. Paul, MN
The furnace is just to the left of these buildings nestled between backdrop and mainline.....not much room to spare! :)
Ralph
MCL_RDG
851
S.E.PA.
"And now...
...we know the rest of the story!", As Paul Harvey would chime.
That's pretty sneaky Ralph! You've removed my quizzle though. The coils ready for loading. The various roof lines shattering the skyline. Now that's kewl!
Your highline concept now rings when I think of the seperation in grade at the old Beth Steel plant in Bethlehem, PA.
Very nice Ralph. I'm not saying that to kiss yer butt either. Well, maybe I am just a little. I love heavy industry.
Mark:D
Ralph
St. Paul, MN
David,
Love the idea of operations programmable paper backdrop trains! I think you just started a whole new branch of the hobby! Loads in, loads out, etc! :D Don't have a lot of money for multi-loco consists? No problem, just scan one engine over and over! :)
Mark, glad the concepts works for you. I know you're a PC/Reading fan so I was wondering. :)
Ralph
brakie
2,827
Bucyrus,Ohio
Ralph,While that looks good I must agree with Mark..The track should go in front of the blast Furnace .this could be done by using a 2 tracks as a "interchange for the steel mill.The steel mill's locomotives would remove the cars.This would give you a true loads/empties in and loads/empties out.All you will need to use is 2 switches..1 from your main line and 1 for the interchange tracks.This takes very little space and improves operation.:D
Ralph
St. Paul, MN
Brakie,
I appreciate the idea...and think the next time I build a layout I will include it. Thing is, this section is nearing completion and it would take a major overhaul to provide track to serve the furnace.
The pic below will explain. I have a long dog bone style plan. Here is the "middle" of it where the tracks create the illusion of a double track main. The rolling mill actually covers the main a bit to break up the view of the track. There is a bridge on the right that goes up and over the track and also takes your eye away from the fact that the main is emerging from the mill.
As you can see I have only a couple of inches between the main and the backdrop as it goes up hill. There's just room for the furnace in between track and backdrop so I thought I'd leave tracks serving the furnace to the imagination.
Next time for sure though Brakie!
