a new way of curving card stock parts
Discussion in 'Tips, Tutorials & Tools' started by buffalowings, Jun 24, 2009.
  1. buffalowings
    buffalowings New Member
    this is a idea I came up with for curving parts, get two aluminum rods, tie them together on both ends or just one, put it on a table, and grab the piece you want to curve, and put it in between the aluminum rods, then pull the card downwards, repeat until you get your desired curveture
    photos should explain process more clearly
  2. buffalowings
    expanded a bit on my idea
    if you need a faster method of curving the parts, curve the part, then flip the rods around and also swap the rods so you can curve it again
    I hope the photos explain my idea
    announce1also, pay attention to the piece of masking tape on the end of the rods
    alas, don't mind the sock in the last pic:cool:
  3. Ronson2k3
    Ronson2k3 Member
    Very cool idea..
  4. buffalowings
    why thank you:wave:
  5. Ronson2k3
    Ronson2k3 Member
    I'm looking at making some large (HO Scale) 8-9 inch diameter grain bins so this should come in real handy.
  6. umtutsut
    umtutsut Member
    No damage?
  7. buffalowings
    I came up with this idea before I even had a papermodel in my hands, therefore, I'm not sure whether or not it will damage the printed side, but I'll test this out when I get my printouts from staples. stay tuned
    but, what I know is, it's better to make multiple passes through the rods, then pull really sharply in one pull, if you pull too hard or too sharp, the paper WILL be creased
  8. luvecraft
    luvecraft New Member
    Great idea sir, thanks for the tips
  9. RickTNRebel
    RickTNRebel New Member
    Great idea, but the aluminum is not a good choice as it leaves black marks on the paper. Stainless steel rod or tempered glass rod would be optimum, unless the marks are of no consequence.
