A short time ago I built for my friend's planed rr-museum a light barrier.
Here a short description of progress.
Material for posts is brass 1/8" diameter. These two samples of posts are turned with a small drilling machine using files and a juweller saw. You should try to use a small drill late for turning a moer great number of posts or check if you can find fitting parts for ship model building.
First samples of the future barrier; here I tested the distance of posts and length of chains between the posts.
Barrier in progress; all posts have got a fine hole below of the head and parts of model chains are mounted.
Five feet of barrier are ready for mounting and I used 76 posts for this length.
Here the principle of my technology.
I used very fine steel wire (diameter 0.1 millimeter approx. 1/256") for fixing the chains to the post. The post is drilled with a hole (diameter 0.4 millimeter approx. 1/64") so that the chain can not go through this hole. Wire is keeped through the holes three times like a double loop (lanyard) where the end links of chain pieces are hooked in the loops. Than I grap both free ends of wire each with a flat plier and so I constrict the loops until wire is pressed into the hole forming a "s". The heavy forming of stell wire avoids that wire is solved byself and I have need a good power for disconnecting the chains form the posts. The result was that the fixed chain links were destroyed however the steel wire was not opened after such an test.
That what I have written is the theory for connecting the chain to posts.
Praxis is shown here.
The previous part of chain (right) is connected to a post and will be connected together with a new part of chain to a new post.
After fixing the chains to post you should watch that the both side fixed chain does not has a multiple torsion in order to get a free swing chain. Turn over the new post until you get a torsion-free chain.
I use such a predrilled wood for setting the ready build barrier.
Last a picture as I mount the barrier to the layout. All holes on layout ground are drilled and posts are glued in position piece for piece. Watch for a correct position of posts so that chains have a straight line. In other case turn the posts before glue is setting.
Wish you good success for own modelling.
See also my "museum thread" where you can get a few first impressions of the rr. museum in progress including this barrier.
Bernhard
Bernhard
