A Fun Game
Discussion in 'Getting Started' started by brakie, Mar 20, 2004.
  1. brakie
    brakie Active Member
  2. Tyson Rayles
    Tyson Rayles Active Member
    Thanks alot Brakie!!!!!!! :mad: :curse: Just what I need another !@$#@%!~@ time waster, there goes my weekend! :p :rolleyes: :D It works great too bad I'm lousy at it. Did I mention there goes my weekend? :D :D :D
  3. Vic
    Vic Active Member
    Fun!!!! Crude but Fun!!!:D :D :D
    But here at The Institute Dr. Feelawright has banned it because he has no meds for the frustration it can cause :D :D :D
  4. Vic
    Vic Active Member
    Fun!!!! Crude but Fun!!!:D :D :D Wheeeee!!!!!!
  5. Vic
    Vic Active Member
    See what it did already....put my post up twice:eek: :D :D :p
  6. rcwatkins
    rcwatkins Member
    I call it, Error! Site cannot be found! :D
  7. RailRon
    RailRon Active Member
    Brakie, that must be one helluva game!
    It put two of our valuable members - Tyson and Vic - mentally out of order, and then it simply disappeared into the electronic Nirvana. :oops: :eek: :p
    Sorry, brakie, I can't find it either. My browser insists that the address can't be found... :cry: :cry: :cry:
  8. brakie
  9. RailRon
    Thank you Larry - now it worked!
    Now let's see... if I push the yellow tank car all the way to the left... hmmm... :rolleyes: ... and then....
    Ron :D :D :D
  10. Lighthorseman
    Lighthorseman Active Member
    I gave up after 125 moves...only having put away 2 cars. :mad:
  11. brakie
    Guys,In say about 3 or 4 days I will show you a easy way of solving the problem..:D
  12. McFortner
    McFortner Member
    Brakie, is that with or without flying switches? ;) :D :D :thumb:
    (btw, this is an EVIL game! I love it.)
  13. N Gauger
    N Gauger 1:20.3 Train Addict
    Cool Brakie :thumb: :thumb: :thumb:
    Is this right??? :D :eek: :eek: :D
  14. b28_82
    b28_82 Member
    yeah i'd say i spent a good hr on the Yard one.
  15. brakie
    Mikey..The first move you want to make is to uncouple the yellow tank car and shove it to the left out of the way.This will give you head room you need to work.Then proceed to switch the other cars out starting with the hopper car.After switching out the hopper for the flat clear switch 2 throw switch pull ahead to uncoupler "C" shove the cars back into the run around track and leave them in the run around track then run around these cars and proceed to switch out the reefer for the boxcar..After completing these switching moves go and pick up the brown tank car.Uncouple this car by using the "A" uncouple.Run to switch #4 and throw switch 1 and 4. couple on to the cars..Proceed and pick up the brown tank car. return to the run around track and uncouple all 3 cars by using the"C" uncloupler.Shove these cars into the clear being sure not to foul the points on switch #1.return to switch 4 and throw switch 4,and 1,then go and pick up the yellow tank car and spot where the brown tank was.Return to switch 6 then proceed to switch 1,throw switch and couple on to your train and go to beans.:D
  16. N Gauger
    Ohhh ok :D :D I thought it didn't matter how you ended as long as you spotted the 3 cars :) :)
  17. scottg28
    scottg28 New Member
    I believe this is correct and my best score so far
    a very fun and entertaining exercise
  18. CarlFidy
    CarlFidy Member
    Which end for loco?
    My take on the game is...
    Local train came from yard(out of view stage left)...switches industrial(sp?) area...then leaves with loco on left side to return to yard...I've done this in 46 moves:) (but can't prove it:( , because I can't figure out how to capture the screen:mad: ...any help on this would be appreciated)
    While writing this post, I tried the puzzle with the loco ending on the other side...came up with 46 moves again:rolleyes:
    Always liked the logic type puzzles, plan on making a small switching layout as my first attempt
  19. scottg28
    scottg28 New Member
    carl, when you are finished, press the "Print Scrn" button, this copies the screen to the clipboard. Then open Paint program, Edit -> Paste and the screen capture will appear. It is a .bmp format, so I usually save as a .jpg and then use a graphics program to resize it for posting.
    Hope that is understandable
  20. DanishKnight
    DanishKnight Member
    FYI: 'Print Scrn' assumes the entire screen is to be captured. If more than one window is open, and just the currently active window needs to be captured, use 'Alt+Print Scrn' and only the active window will be sent to the clipboard.
