A fishing line waterfall
Discussion in 'Photos & Videos' started by Ralph, May 10, 2003.
  1. Ralph
    This waterfall is at the end of a canal in an industrial scene on my layout. Following a technique I remembered seeing in an issue of Model Railroader, I cut a piece of thin plexiglass to fit the waterfall area and wrapped transparent fishing line tightly around it, cementing the ends of the line to the back of the glass. I then glued the wrapped plexiglass in place, put cotton ball fiber at the bottom to represent churning water, and then applied several coats of acrylic gloss medium, letting it flow down the vertical falls.
    The canal was made from a masonite base coated with joint compound and stipled wtih a damp sponge when wet to create ripples and waves. I colored the "water" with Woodland Scenes Stone Gray pigment unduluted right out of the bottle. Gloss medium added the sheen here as well.
  2. Drew1125
    Drew1125 Active Member
    That looks great Ralph!
    I remember that MR article too...
    I'm pbobably going to try something like this too, since I have a couple of places on the layout for waterfalls.
    Thanks for sharing! :cool:
  3. Duckman
    Duckman Member
    Hi Ralph, Great work, I, ve always wanted a waterfalls on my layout. I,ll try it .Thanks for the info. Duckman..;) ;) ;)
  4. K.V.Div
    K.V.Div Member
    Great waterfall Ralph!, I also remember the MR article and it is good to see another of these ideas and tips put to good use. :)
    I forgot all about it and now that you have shown it on your layout, I now have another scenery idea for my oNeTrak bridge module ;)
  5. ezdays
    ezdays Out AZ way
    Wow!!!! Great idea, I'm sure it take a lot of patience, but the effort is worth it. I like your track weathering as well.:)
    D:cool: N
  6. shamus
    shamus Registered Member
    Looks very good indeed Ralph, great work
