3 Rail Reversing Crossover Wiring
Discussion in 'G / O / S Scale Model Trains' started by tcpilot, Oct 3, 2007.
  1. tcpilot
    tcpilot New Member
    Hi all! I've been watching the forum for a while but this is my 1st post. I've searched previous posts but can't seem to find any info. I have a fastrack layout with a reversing crossover (isolated with block section track). I'm not running DDC (I use a CW-80). How do I wire the layout for reversing polarity?
  2. pgandw
    pgandw Active Member
    3 rail means never having to worry about reversing sections! :thumb:
    The center rail is always the center rail, all the way through reversing loops, wyes, and turntables. The outer 2 rails are always of the same "polarity". So there is no "polarity" reversal to contend with in 3 rail. Just wire it as a normal block or track section and everything will work fine.
    yours in wiring
  3. tcpilot
    tcpilot New Member
    Thanks for the info. I was thinking that was the case.
