2 more for the collection
shamus
Registered Member
Dec 17, 2000
3,489
UK
Two more scratchbuilt pieces of rolling stock for the 0n30 collection.
Top photo is a Wheelcar, underneath is the Blacksmiths car
shamus
shamus
Registered Member
Dec 17, 2000
3,489
UK
Hi camelot , yes thats one of two shay I have. Trying to find out how to remove the cab from one of them, so far no luck.
shamus
Matthyro
Will always be re-membered
Dec 28, 2000
4,550
Georgetown, Ontario,Canada
Very impressive Paul, The large scale must be a delight to work in but at the same time, more and more details become necessary and you are the master of fine detailing. Nicely done.
sumpter250
multiscale modelbuilder
Jan 19, 2002
3,073
Vernon Hills, Illinois
Paul,
You will have to pull all the piping out of the front wall of the cab, and break the engineer's, and fireman's seats out. They are plastic, and glued in place, they come out easily enough with a little pressure from a small flatblade screwdriver.
Then, on the engine side, just in front of the step, there's a small plastic "wedge", held in place with a tiny flathead phillips screw. Remove the screw, and carefully remove the wedge, and the cab slides to the fireman's side and the three lugs will clear the frame and the cab comes up off the frame.
Pete
