nolink5750
Ok, this is wierd. I am working in a confined area. I soldered my corners together (6) 19" rad. and put a 5" str. at each end. Hoping that I can set it in one piece. After soldering is done, I can actually move it, like it is flex track. Not as much, but I can move it. Is this normal? I mean in a way I like it because when I put (4) together to make a oval they didn't line up right. But I just realized that I can move them. And when I do it's not the joints are coming apart either. It just moves. I hope this makes sense cause I'm ready to start laying the track.
P.S. can someone tell me where the radius is located to? I want to make a templete so I make sure every thing is right on. I mean is it to the center on the rails, the inside or outside???? Thanks..............
