1/48 Republic XF-103 Thunderwarrior
Discussion in 'Gallery & Designs' started by NOBI, May 20, 2007.
  1. charliec
    charliec Active Member
    It was. I think the reasoning was that if the US was building a Mach 3 bomber (B-70) the Russians would probably be able to build one so the US had better cover that possible threat with an interceptor. The XF-103 was designed with Mach 5 performance as a goal - the airframe was supposed to be built in Titanium with a ramjet engine to provide high Mach thrust. It was serious enough that the US put money into the French experimental ramjet interceptor program.
    The whole program was rendered silly by the advances in missiles and the difficulties encountered in fabricating in Titanium. As an aside I'm not sure where they thought they were going to get the Titanium from - the SR-71 Titanium came mostly from Russia.
  2. NOBI
    NOBI Active Member
    Tonight I add all of panel line into surface...only decal left and then unfold :)
  3. Stev0
    Stev0 Active Member
    Another great vehicle awaits final Nobification.
    ps. Thank you for the new flier Freebie. I'm gonna print it along with the Cromwell tank to get a friend hooked on card modeling (ironically his last name is Cromwell).
  4. NOBI
    NOBI Active Member
    A little bit progress with decal on mesh
    and compare 3 steps before unfold
  5. cmdr199212
    cmdr199212 Member
    how do u get rhino?
  6. Bowdenja
    Bowdenja Active Member
    First you win the lottery...................
  7. Maurice
    Maurice Member
    Time for Tim to get a bit miffed.
  8. Bowdenja
    Well.............. I was joking. :grin:
    But you get what you pay for.
    The stuff that is done with Rhino has always impressed me, but the price is out-of-my-league for now.
    Of course............... the software does it all, the designer just types right?
    P.S. I'm joking on the last line.................. old Data Processing adage............. Garbage in......... garbage out.
  9. Maurice
    Maurice Member
    ... that's right John, the designer just types .... ... pats gently on head and backs away ... ... :grin:
  10. NOBI
    NOBI Active Member
    Unfold nearly finish...post some progress first... only internal former and connection strip left
  11. wunwinglow
    wunwinglow Active Member
    De-wrinkled your hull yet, Maurice? :wink:
  12. Alcides
    Alcides Member
    Another winner by NOBI :grin:
    Nobi, do you have a technic for the stripes. I tired to draw small lines in my project :(
  13. Bowdenja
    Tim! Tim! Tim!:rofl:
  14. Maurice
    Maurice Member
    Seriously miffed. :grin:
    So I'm not supposed to respond at all but you can lash out instantly - thought so Tim - was just checking.
    (For those who didn't see it, Tim's pathetically illogical suggestion that I should continue to not respond to his unpleasantness was deleted along with the thread it was in.)
    Still it's edifying to see that a first run at the hull made such an impression on someone who doesn't even know that there is a difference between lbp and lwl.
  15. wunwinglow
    I see no wrinkles... (paraphrasing someone nautically famous)
  16. NOBI
    NOBI Active Member
    Hi Tim
    Rhino 4 ? :)
  17. NOBI
    NOBI Active Member
    Update today :) all parts arrange on letter size page. Only Connection strip left. I will post how to make connection strip from Rhino for people who interest too :)
  18. wunwinglow
    Hi NOBI,
    yes, Rhino v4, although I did most of the work on this project in v3.
    This is a design for resin casting in 1:200 scale, so the hull master will be CNC machined, moulded in RTV rubber and cast with photo etchings etc. for the smaller parts. Another long term project.....
  19. Maurice
    Maurice Member
    As an initial interpretation of the available body plan of the Bonaventure, without any further attempt to adjust sections and fair the lines ..... that's not very good.
  20. Alcides
    Alcides Member
    NOBI I'm waiting for you release and the tutorial !!! Please. Please.
